Author Topic: Steering lock locked!  (Read 3729 times)
bobcalvert
  • essex
« on: 07 August 2008, 09:36:00 »
Hi, i wonder if anyone can help, my omega 2.5 estate N reg, the steering lock has engaged and you cant turn the key to unlock it...tried all the usual tricks like wd40 etc but to no avail...the AA man couldnt do anything either, however due to time restraints i had to get it towed home instead of to a garage...
now ive got a car on my drive i cant take anywhere as the steering lock is in...how do i get it out so i can get it to a garage? or replace the lock?
Re: Steering lock locked!
« Reply #1 on: 07 August 2008, 09:37:31 »
see maintence guides area on ignition barrel....
bobcalvert
  • essex
« Reply #2 on: 07 August 2008, 09:39:28 »
it says turn it to position 1, however i cant get that far...can it still come out that way?
« Reply #3 on: 07 August 2008, 10:04:12 »
You need to wiggle the key whilst turning it, try pulling it out ever so slightly to.
« Reply #4 on: 07 August 2008, 10:04:58 »
Ow yes, use a light oil or proper penetrating fluid, WD40 is a crap lubricant
ians
  • Reading
« Reply #5 on: 07 August 2008, 12:36:05 »
just keep wriggling.   it took me hours on mine.   Its not much help to you now (mut maybe someone else reading this) but if you start having problems turning the key, get it sorted straightaway, as you need to be able to turn the key to fix the problem (catch 22..)
Once it turns, leave it there and proceed with the barrel removal proceedure.
bobcalvert
  • essex
« Reply #6 on: 20 August 2008, 21:40:34 »
still not getting anywhere, have been waggling away for ages, nothing much seems to be shifting it.
Can it be smashed off, or can the steering lock be snapped off by janking the wheel?
anyone got any more ideas?
otherwise im going to have to scrap the car at this rate.
Cheers
Bob
holtender
  • Suffolk
    • 2.5 CDX Facelift
« Reply #7 on: 20 August 2008, 22:12:29 »
Without going out and inspecting my own, is the steering lock on an Omega fixed to the steering column with a shear bolt, does anyone remember?
If it is then it can be removed with a little know how and the lock will then come off easily!
« Last Edit: 20 August 2008, 22:23:06 by holtender »
Bandit127
« Reply #8 on: 20 August 2008, 22:44:56 »
Plus Gas
Nice to know it's still around.
WD40 still has it's uses though; as somebody who used to have to leave their bikes outside, igintion barrels and steering locks is one of them.
A good soaking through the key slot - one in October and another one around January - would get you through the winter without a frozen lock.
« Reply #9 on: 21 August 2008, 08:43:02 »
Correct, it is secured with a sheer bolt which would need drilling out (although sometimes you can tap them round with a chisel.)
holtender
  • Suffolk
    • 2.5 CDX Facelift
« Reply #10 on: 21 August 2008, 18:01:58 »
Ok then it is a shear bolt.
A shear bolt is a bolt that shears off when tightened leaving a convex end something like the end of a pencil. The steering lock is fixed to the steering column using such a bolt.
To remove it you need to access your steering lock and using an eigth drill bit, drill a small hole in the convex end of the bolt at 10 to 12(this might be difficult because of lack of access for your drill and the drill bit will tend to slip)
When you have drilled a small hole just deep enough to allow a centre punch to be gently tapped around anti - clockwise you will find the bolt is not too tight and should move easily.
I have done this job many times over the years and it is very easy to do, if a little awkward.
Best of luck and keep us posted if you need any help.
kris9128
« Reply #11 on: 21 August 2008, 19:47:43 »
i used to remove them by getting a goo phillips screwdriver and a hammer. put the driver in the centre of the shear bolt head and give it a good couple of whacks with a hammer. then just unscrew it.
yingtong
  • North Staffordshire
  • Lord of the ANTI-BLING
« Reply #12 on: 22 August 2008, 17:52:46 »
Is your miggy an auto?
Back in the fast lane !!!
Bandit127
« Reply #13 on: 22 August 2008, 18:03:41 »
If it is an auto, is it in Park?
bobcalvert
  • essex
« Reply #14 on: 22 August 2008, 18:09:04 »
yup its auto, and its in park
