Author Topic: why is my exaust so noisy  (Read 1419 times)
Richie London
  • heathrow
« on: 25 August 2008, 15:43:05 »
have had a look underneath, cant see any holes anywhere but its starting to sound like a loud diesel car. they have put a speed ramp in the pub car park and its not an ordinary bump, it must be a half circle shape, about a ft wide and 5 inches high, i did wack the cats as i went over it, and that was real slow too.
could i have done some damge as to make the exaust so loud now???
FRE07962128
Re: why is my exaust so noisy
« Reply #1 on: 25 August 2008, 16:07:28 »
Sounds (scause the pun! :D) like it!   All it needs is a small weakness in the pipework or boxes, and this will cause a fracture / leak that may by almost invisable. :'(
Put the car on a ramp / jack it up and pass your hand over the exhaust from the engine end back and no doubt you will find the hole!! ;)
« Last Edit: 25 August 2008, 16:08:39 by FRE07962128 »
Richie London
  • heathrow
« Reply #2 on: 25 August 2008, 17:07:57 »
there seems to be a lot of heat rises from under my door, can feel it with my arm on window edge.
FRE07962128
« Reply #3 on: 25 August 2008, 17:14:05 »
I often notice that myself with my (new) exhaust, but excess heat would be another clue to indicate hot gases escaping from the exhaust / cats. ;)
Worth checking that area in particular as stated before.  A join at least could have parted :-/
« Reply #4 on: 25 August 2008, 17:19:07 »
I get the same on mine, stood in traffic, suntanning the right arm etc, but with 2 pipes travelling under a car with a V6 lump in it and no air flow under the car then I would expect the heat.
Richie London
  • heathrow
« Reply #5 on: 25 August 2008, 17:19:07 »
i'll have to take it to garage fri morn to get them see.  :y :y
« Reply #6 on: 25 August 2008, 17:20:15 »
Start it up and get some to keep holding a rag over the end of the exhaust then listen to see where it blows. :y
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
« Reply #7 on: 25 August 2008, 17:30:26 »
EGR Bypass pipe ?
Down on the NSF of the engine - Mine spilt and it sounded like the manifold was blowing
Richie London
  • heathrow
« Reply #8 on: 25 August 2008, 17:45:51 »
EGR Bypass pipe ?
shall take a look tonight at work then.  :y
