Author Topic: headgasket ? thin oil, engine noisy....  (Read 2673 times)
yorkshire ripper
  • leeds
« on: 23 August 2008, 19:34:49 »
oh shit..here we go again. im loosing water out of the header tank, when i dip the oil its very thin,no gunge tho. filter and oil changed last week. rocker cover gasket changed yesterday. ran fine last night. got up this morning, has lost more water out of the header tank and sounds like a rough diesel. no overheating at all or steam.. :-?
is there anywhere else water can get in the oil ?
please help before i sell the car, its doing my head in....lol
Re: headgasket ? thin oil, engine noisy....
« Reply #1 on: 23 August 2008, 21:49:50 »
maybe fuel is thinning the oil. if its running rough at any point and water is separate issue? have you been through the hbv malarkey?
yorkshire ripper
  • leeds
« Reply #2 on: 24 August 2008, 17:02:37 »
update....
had the car on axle stands today, wiped everything  clean underneath the engine/box. started car to see if theres any water leaks....nothing :'(
car sounds like a bag of spanners due to thin oil, now eml has come on. is headgasket a big job on the 2.0 ? cant think of anything else it could be...
any help/info would be great..
thanks
lee
« Last Edit: 24 August 2008, 17:08:23 by yorkshire_ripper »
star_whites
  • Rotherham
« Reply #3 on: 24 August 2008, 17:15:11 »
It sounds very much like HG to me. Thats what mine was doing prior to going altogether.
If you decide to do the head I would recommend if your a capable mechanic to do it yourself. That way you know what parts get fitted and you know it will be done right. I did mine in just over two days. Make sure you get the head skimed though.
« Reply #4 on: 24 August 2008, 17:26:08 »
Get a compression tester on it before ripping it all apart
yorkshire ripper
  • leeds
« Reply #5 on: 24 August 2008, 18:42:35 »
i'll get a comp test done tomorrow. any tips on doing the HG i need to know ?
cheers
lee
yorkshire ripper
  • leeds
« Reply #6 on: 25 August 2008, 17:00:28 »
have i got an oil cooler on this engine ? ive been searching but can only find info aout the v6 engines. ive got one on my gtr so i know what they look like but cant find owt on my mega?
cheers
lee
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #7 on: 25 August 2008, 18:30:07 »
No oil cooler on 4 pot.
« Reply #8 on: 25 August 2008, 18:36:21 »
It sounds like mega over fueling to me resulting in bore wash and hence the thin oil and noisey engine.
yorkshire ripper
  • leeds
« Reply #9 on: 25 August 2008, 18:53:03 »
hi mark
is there any easy way to test for over fuelling.  checked the hbv for leaks again today and its bone dry.just a bit puzzled as to where the coolant is going ? im gunna change the oil and filter tomorrow and give her a good run. if i do a paper clip test will it throw owt up that will point to fuelling ?
cheers
lee
