Author Topic: coolant problem  (Read 1750 times)
craig
  • north wales/connah's quay
coolant problem
« on: 25 August 2008, 20:53:08 »
i drove today for about 30miles and the check coolant level display come up so i opened the bonnet and the water was lowish but not really low so as i tryed to fill it up,it filled up again when i unscrewed the cap to perfect and there was a water sound as if there was a air lock or something to the engine ::)Any ideas please :y
Re: coolant problem
« Reply #1 on: 25 August 2008, 20:55:09 »
The level will always rise when you undo the cap after the engine has been running.
If there are no external leaks and the temp is stable I don't think you have a problem.
craig
Re: coolant problem
« Reply #2 on: 25 August 2008, 21:00:16 »
yeah temp was fine and no leaks :y :y
its just that noise to the engine after the ignition was off or is that normal after opening the cap when engine is hot ::) ::)
Dazzler
  • Haverhill, Suffolk
Re: coolant problem
« Reply #3 on: 25 August 2008, 21:00:31 »
Just keep an eye on it.
When its cooled down, make sure the level is spot on, then keep an eye on the level.
If it keeps dropping then you will have to locate the leak and rectify.
craig
Re: coolant problem
« Reply #4 on: 25 August 2008, 21:06:53 »
will do mate cheers :y
craig
Re: coolant problem
« Reply #5 on: 25 August 2008, 21:07:53 »
sorry James wheres my manners ::) cheers mate :y :y
