Author Topic: Autobox  (Read 2715 times)
Crazydad
  • Germany
    • 2.5 V6 facelift
Autobox
« on: 25 August 2008, 21:09:20 »
Any advice on this problem would be very much appreciated:
After oil lines had been changed to the Autobox a small amount of atf was lost, and now thereis a big pause when moving off from stationary
There are no gearbox messages or anything like that, and it seemed to drive smoothly.
Any thought anyone? :-/
Omegatoy
  • UK
Re: Autobox
« Reply #1 on: 25 August 2008, 21:11:31 »
low fluid, !!!! did you not top it up afterwards? it may have been low before and you made it worse!!!
Crazydad
  • Germany
    • 2.5 V6 facelift
Re: Autobox
« Reply #2 on: 25 August 2008, 21:14:23 »
will check asap,
 could`nt  be anything else could it?
Re: Autobox
« Reply #3 on: 25 August 2008, 21:15:56 »
Slowness of it engaging drive or rev is usually always low atf.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Autobox
« Reply #4 on: 25 August 2008, 21:17:54 »
Make sure you check the level though Steve with the engine running aswell as it being level :y
ians
  • Reading
Re: Autobox
« Reply #5 on: 25 August 2008, 21:19:16 »
Definitely with the engine running or you will get covered in fluid the moment you undo the filler plug. ;)
Crazydad
  • Germany
    • 2.5 V6 facelift
Re: Autobox
« Reply #6 on: 25 August 2008, 21:22:11 »
Cheers guys appreciate the help :y :y
Re: Autobox
« Reply #7 on: 25 August 2008, 21:22:42 »
In fact, sod it, its the ideal opportunity to replace all the ATF :y
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Autobox
« Reply #8 on: 25 August 2008, 21:23:47 »
If he goes that far he may aswell do the filter and gaskets for 30 odd quid
Re: Autobox
« Reply #9 on: 25 August 2008, 21:27:23 »
Yup, thats what I meant...
