Author Topic: lower front suspension arm  (Read 1853 times)
stevencarter
  • Poole, Dorset
« on: 26 August 2008, 18:03:45 »
Does anyone know how much vx charge for front lower suspension arms,(pair), with trade card. I had a look on the website but there was no price listed for it. Also what part numbers do i need for the front discs and pads for a 98`R 2.0l 16v omega,(only listing showing was up to 97). Thanks.
hotel21
  • The Kingdom of Fife
Re: lower front suspension arm
« Reply #1 on: 26 August 2008, 18:10:09 »
Lower arms from VX are extrotionate.  Dunno the exact price but its up there in the couple of hundreds...  And, as far as I know, its not on trade club...  Plenty of folks here have used alternates sources from e-bay and similar.  Check some of the past threads and you will see whats meant.
As to the discs and pads, cant lay my hands on numbers etc but they are on trade club.  Last i saw, somewhere in the £60 for an axle set of discs andpads.....
« Reply #2 on: 26 August 2008, 18:10:51 »
They are silly money from Vauxhall. Give this place a call http://stores.ebay.co.uk/VAUXCENTRE_W0QQcolZ4QQdirZ1QQfsubZQ2d999QQftidZ2QQtZkm
I paid about £55 for both sides delivered
stevencarter
  • Poole, Dorset
« Reply #3 on: 26 August 2008, 18:28:31 »
thanks for the advice will start looking around to see what i can find.
lpgelite
  • Cumbria
« Reply #4 on: 26 August 2008, 21:12:05 »
johnnycboy
  • Colchester
« Reply #5 on: 26 August 2008, 21:15:04 »
I think these are genuine GM @ £25 a side + p&p.
http://www.vauxcentre.co.uk/index.php?option=Prod_detail&product_id=485975&image_id=190941
not genuine but have used them myself. good for the money. gm parts about £200 each
LaserLance
  • medway towns
  • Red or Black please!!!!!!!
« Reply #6 on: 26 August 2008, 22:12:25 »
i was quoted £236 for wishbones by the stealers(Greens of Rainham) but thats everything included ie track rods and sterring idler. nearly had a heart  attack on spot  ;)nearly as bad as when i asked how much to set up tracking geometry 1 hours labour £ 84 + parts , methinks someone is extracting the urine a bit when its come to labour  >:( >:(
« Reply #7 on: 26 August 2008, 22:14:12 »
I believe these have the Boge bushes, there the ones to go for :y
« Reply #8 on: 26 August 2008, 22:19:23 »
Just bought front discs + pad set from Vx on TC - £71.40 + VAT - sure they're the same for 98 2.0Lit as 2.5V6.
Part Nş - 93175466
« Last Edit: 26 August 2008, 22:21:01 by dbug »
« Reply #9 on: 26 August 2008, 22:21:12 »
i phew alternatives for you to consider, as vx want about 400 plus for a pair. Dont go there for wishbones. Discs are considered good value from what ive read on here esp with tc card.
Original wishbones made by lemforder can be had from autovox for 120 plus delivery, only difference is no gm badge.
 Or as Johny says the cheaper still options
Linked above for roughly 50 a pair but are considred not to last as long,although as you can see, those that have them seem quite happy.
Failing that you can press new bushes in but you need access to 10 ton press and the right drifts to avoid damaging the wishbones or the bushes. Hope helps.
See the guide in maintenance section for correct torquing procedure, get it wrong and your back to square one a bit sharpish. Hope helps.
stevencarter
  • Poole, Dorset
« Reply #10 on: 27 August 2008, 09:55:04 »
thanks for the help, just got some ebc discs and pads for £125 delivered, still looking fo wishbones, sure i`ll find some somewhere.
hotel21
« Reply #11 on: 27 August 2008, 20:15:02 »
As to the discs and pads, cant lay my hands on numbers etc but they are on trade club. Last i saw, somewhere in the £60 for an axle set of discs andpads.....[/quote]
did you miss this one??
« Reply #12 on: 27 August 2008, 20:17:30 »
£71.40 + VAT for discs/pads now...
