Author Topic: CLIMATE CONTROL = POWER LOSS  (Read 874 times)
surj
  • birmingham
    • omega mv6 3.2 v6 auto
« on: 30 August 2008, 22:49:01 »
Hi everyone ,  i was just wondering how much power does the use of the climate control in an omega 3.2 use up . The reason why i ask is because when i was at a standstill i pressed the economy button on the heating fascia and the engine seemed to really just quieten down as if it were just ticking over , but when turned to auto mode it felt the engine was just working that bit more  plus the extra engine noise!!
hotel21
  • The Kingdom of Fife
Re: CLIMATE CONTROL = POWER LOSS
« Reply #1 on: 30 August 2008, 22:52:21 »
Moved to the techy bit as thats where it will probably get most replys.....   ;)
    • 530D M Sport, 330i Coupe
« Reply #2 on: 30 August 2008, 22:52:39 »
I find it's the aircon fans that makes all the noise, When I switch the A/C off the biggest noise under the bonnet is the fuel injectors, the engine ticking over is barely audiable.
« Reply #3 on: 30 August 2008, 22:53:11 »
IIRC (and I probably don't ...  :) ) I think its a 5 HP compressor .. as the 3.2 pushes out 217 HP it makes little difference  :) - well I've never noticed it anyway !!
The ECU does change the idle speed by about 100 rpm when climate is on, and both the front fans run at slow speed which is what you may be hearing ...
HTH
« Reply #4 on: 31 August 2008, 00:06:36 »
Most AC compressors take 3-5 bhp.
The revs jump up a bit on any A/C car when compressor on, just to help it run a little smoother...
