Author Topic: idle valve  (Read 1055 times)
omegabeaver69
idle valve
« on: 31 August 2008, 09:39:10 »
hi engine races up to 2000 revs and back down again in idle  so can i suspect idle valve 2ltr gls  :( :D
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: idle valve
« Reply #1 on: 31 August 2008, 09:40:56 »
Clean out the ICV and the breathers, there's an excellent guide in the Maintenance section.
I like red cars
Re: idle valve
« Reply #2 on: 31 August 2008, 14:34:37 »
Re: idle valve
« Reply #3 on: 31 August 2008, 16:37:16 »
air leak to inlet system? Above mentioned and cam sensor are common on 4 pots. Breathers will probably need doing what ever. :y
ians
  • Reading
Re: idle valve
« Reply #4 on: 31 August 2008, 17:42:47 »
as said, do a thorough job cleaning brether pipes (particularly the small one AND the metal nozzle it connects to below the throttle body.
Use new gaskets when reassembling (cost pennies from Vx)
Also check none of the vacuum pipes have come adrift.
