Author Topic: Quick Oil Filter Question  (Read 2124 times)
Tresvant
  • Nottingham
« on: 30 August 2008, 13:01:23 »
Sorry to bother you guys with this but i was all geared up to do my first ever oil and filter change today until i went to get the filter. I was more or less sure that on my s reg 98 2.5 v6 my oil filter is the canistor type but the guy at the spares place tells me its a paper filter one. So my question i guess is which one is it??
many thanks
steve
Re: Quick Oil Filter Question
« Reply #1 on: 30 August 2008, 13:54:54 »
In the crossover period, it could be either.  You'll have to physically check.
« Reply #2 on: 30 August 2008, 14:17:16 »
Easy enough to tell as you can see it from the engine bay
Tresvant
  • Nottingham
« Reply #3 on: 30 August 2008, 14:56:14 »
Thanks, but i know i am going to sound like a total idiot but not sure what i'm really looking for. Never done anything like this before and i was relying heavily on the guide from here. I know that complete numptys like me probably frustrate you guys but any help would really be appreciated, cant see it from looking inside the engine bay or at least i dont think i have seen it so i will go and jack the car up on the passenger side and have a look. Also whilst i am here i seem to have a large amount of oil everywhere mainly around the top which i am guessing is the cam cover gaskets and also at the rear of the engine on the drivers side, this of course could be a build up from many years of neglect so am i best to clean it up and then see if i can see where its coming from?
sorry for being sooo stupid  :P
thank
steve
Alex W
    • 2000W Facelift 2.5V6 Elit
« Reply #4 on: 30 August 2008, 15:28:14 »
If you go to this link in the maintenance guide:
http://www.omegaowners.com/forum/YaBB.pl?num=1204142232
You will see photos of both types.
« Reply #5 on: 30 August 2008, 15:41:18 »
Youb can see it from under bonnet - passenger side towards back of engine look down - its about halfway down the block.
« Reply #6 on: 30 August 2008, 18:19:32 »
But probably easier, if you don't know what you are looking for, to poke you head underneath...
Tresvant
  • Nottingham
« Reply #7 on: 30 August 2008, 20:02:06 »
i assume this is what i am looking for, and if so is this the paper element type??
Cheers
« Reply #8 on: 30 August 2008, 20:02:38 »
Cheers
Yes and yes  :y
Tresvant
  • Nottingham
« Reply #9 on: 30 August 2008, 20:04:01 »
Thanks everybody, sorry for being a pain, but its something that i will now know forever.
cheers again
Steve
Big_Roger
  • Southampton
« Reply #10 on: 31 August 2008, 21:08:49 »
Make sure you use a 24mm socket or ring spanner first to undo the end cap.
If it is very tight, using a 3/8 square drive in the end will split the cap, though it's OK once the cap is free.
Roger
Be patient ! Something else will go wrong for you to fix if you wait long enough !!
« Reply #11 on: 31 August 2008, 21:22:23 »
Do NOT overtighten on re-fitting like most garage numpties do .. it only needs a tiny tweak .. if you have a low range torque wrench its 15 Nm according to the book of lies .. I use 8 Nm and have never had a problem :)
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #12 on: 31 August 2008, 21:28:07 »
As cast into the metal filter end cap.
Shame these monkeys can't read it.
TuBy's new whipping boy.
