Author Topic: abs, tc, speedo problem  (Read 3099 times)
kris9128
« on: 29 August 2008, 15:57:50 »
have an intermitent proplem that i cant seem to trace. problem started shortly after changing alternator. driving along, speedo dies and abs/tc lights come on. can stay like that for 30 seconds or 1.5 hours. then speedo starts working and abs/tc lights go out. cant work out why this has only started the same day i  changed the alternator. dont know if it helps but i changed all discs and pads about 3 weeks ago. any help greatly appreciated. many thanks
sophos9
  • Norfolk
Re: abs, tc, speedo problem
« Reply #1 on: 29 August 2008, 16:47:54 »
Can you measure the voltage across the battery with ignition off.
Now, measure the voltage across the battery with the car running, possible over-voltage (alternator rectifier)...
« Last Edit: 29 August 2008, 16:48:13 by sophos9 »
« Reply #2 on: 29 August 2008, 17:05:40 »
Had this on the old miggy ... abs ecu is in the process of failing  :(
There is a "how to" on how to change it ...
http://www.omegaowners.com/forum/YaBB.pl?num=1152729807
VX wanted £700+ for a new ECU  :( .. I got mine repaired by bba reman for £130 including courier fees on a 5 day turn around ...  I was VERY impressed with their service.
Advantage of having yours repaired is it does not then need the tech2 treatment   :y :y
http://www.bba-reman.com
Give them a ring on 01634 687222 and have a chat .. could save you loads of dosh !!  :)
« Last Edit: 29 August 2008, 17:07:37 by entwood »
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #3 on: 29 August 2008, 17:07:16 »
This could be indicative of the ABS ECU going. If you have cruise control does that also stop working.? I hope it isn't as it is quite a fiddly job to do. Do a search on the forum on how to change them/get them refurbished etc.
In the meantime well worthwhile trying all the other suggestions people will make.
varche
Derek_in_Penzance
  • Penzance, Cornwall
« Reply #4 on: 29 August 2008, 18:38:50 »
Agree with above, having had same symptoms on my  car, I'd say there's a high probability that the ABS ECU is failing. Not good I'm afraid, as apart from the cost of repair, the pump/ECU assembly is difficult to get to. Six small screws will drive you nuts!
Go to Facebook and become a Fan of the GM6 Spares Facebook page. Omegas dismantling, mail order parts & servicing. Tech 2 services available.
Dazzler
  • Haverhill, Suffolk
« Reply #5 on: 29 August 2008, 18:49:14 »
But is more then doable with a bit of patience :y
kris9128
« Reply #6 on: 29 August 2008, 19:54:09 »
cars only done 51k miles. surely the abs ecu sshouldnt be on its way out.
« Reply #7 on: 29 August 2008, 20:38:34 »
Definately abs ecu packing up.  Contols abs, tc, speedo, cruise and speed sensitive power steering.
Options - recon bba as Entwood above OR
get used off breaker for exactly same year and model spec as yours.
I went down used route with Estate and all worked ok 1st time without need for Tech2!
It is an rsol of a job to do - need lots of patience to get all 6 screws out and usually 4/5 (5 in my case) back in!
Good luck
« Last Edit: 29 August 2008, 20:39:02 by dbug »
sophos9
  • Norfolk
« Reply #8 on: 29 August 2008, 21:06:06 »
Have you checked voltages?
« Reply #9 on: 29 August 2008, 21:47:11 »
Yeah, abs ecu. Can be refurbed for 125 quid, but bit of a bitch to remove/refit
Varche
    • Golf Estate
« Reply #10 on: 29 August 2008, 22:01:48 »
"need lots of patience to get all 6 screws out and usually 4/5 (5 in my case) back in!"
Lightweight! ;D ;D ;D
varche
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #11 on: 29 August 2008, 22:33:16 »
it seems to be common with 99-01 cars, we have seen a lot of them....
Mine was exactly the same, ABS ECU was the cure.....
Dazzler
« Reply #12 on: 29 August 2008, 22:38:49 »
and mine ::)
MarkG
  • Northwich, Cheshire
  • "An Omega? Been a while since I saw one of those!"
    • 2000 CD 2.5 V6
« Reply #13 on: 30 August 2008, 07:49:57 »
My facelift car is the same year and engine as yours. The same thing happened to mine about 3 years ago. I checked the ABS ECU part number with vauxhall and then found one from a breakers. Think I paid £40. Mine actually came from a 1999 pre-facelift. Had it fitted by a local garage for two hours labour and it has been just fine ever since.
« Reply #14 on: 30 August 2008, 15:56:53 »
varche
You got all 6 back in?  I take my hat off to you.  ::)  After getting 5 back in and getting p*ssed of with the sixth (bottom right looking from front) i thought b*llox can't see that the last one is absolutely necessary!  No probs to date :y
