Author Topic: Dis Pack  (Read 3326 times)
amba
  • Medway towns
    • German V6
Dis Pack
« on: 30 August 2008, 13:21:06 »
Just come home from France after driving over 2500 miles in 18 days without a hitch,car ran perfectly and was a pleasure to drive.
Since returning home have now got a intermitent miss fire which after checking with a mechanic friend diagnostic readout and reading previous threads on the forumwe are now of the strong opinion that it is the dispack,especially as plugs/leads/cam covers and gaskets were replaced several weeks earlier.
Rang VX and have been advised that engine could have 1 of 3 different dispacks fitted ???Is it possible to establish which sytle and model is fitted without a total removal of existing unit as was hoping to be able to go out later today and get a replacement and then fit on sunday,as with car in pieces have limited options for tracking down a replacement.
Any advise please .Thanks
MarkG
  • Northwich, Cheshire
  • "An Omega? Been a while since I saw one of those!"
    • 2000 CD 2.5 V6
Re: Dis Pack
« Reply #1 on: 30 August 2008, 13:31:12 »
I thought there was only two types. The difference is the connector. On one it is oval and on the other it is square. You can only tell which one you have when you start stripping things out. It is a bugger to get at!
You can get original Bosch ones from your local spares place without having to go to Vauxhall. Strangely one type is £30 or £40 more than the other.
You could buy both and take the wrong one back or take a chance and buy the cheaper one with the sqaure connector first. It seems to be the more popular one
amba
  • Medway towns
    • German V6
Re: Dis Pack
« Reply #2 on: 30 August 2008, 13:45:48 »
Thanks for advise MarkG.
Remember doing the same with crank sensor..sure local Motor Factors told me they list 3..so if the only difference is the square or oval plug is it possible to see enough with scuttle etc removed as would like to try and source today ready for the skinned knuckles on Sunday
JueV6
  • Kent
Re: Dis Pack
« Reply #3 on: 30 August 2008, 13:47:35 »
I have an almost new one from the MV6 i'm breaking, It had a missfire when i picked it up so went and got 1. Square plug  :y
amba
  • Medway towns
    • German V6
Re: Dis Pack
« Reply #4 on: 30 August 2008, 13:59:18 »
Thanks for kind offer JueV6.I was hoping to get things put back on Sunday,but as my local Motor Factor is unable to let me know if they have the correct 1 in stock until I remove the old 1,even with "next day delivery" won,t get yours till  Tuesday at earliest,unless you fancy a trip to Kent ???
Drop me a pm with £££,s you are looking for and might take you up if other options fail.
Just would be good to know which one is needed without total removal.
Re: Dis Pack
« Reply #5 on: 30 August 2008, 14:03:37 »
Hmmmm, migh be worng but, DIS packs rarely cause an intermittent miss fire!
JueV6
  • Kent
Re: Dis Pack
« Reply #6 on: 30 August 2008, 14:07:36 »
the one on this MV6 did MDTM, only missed on number 1 cyl too. On the way back from Croydon it cured itself for a while and then resumed it normal miss,
Re: Dis Pack
« Reply #7 on: 30 August 2008, 14:09:43 »
Still dont beleave it.
When you consider each coil on a DIS pack feeds two plugs an th failure mechanisms involved!
JueV6
  • Kent
Re: Dis Pack
« Reply #8 on: 30 August 2008, 14:52:55 »
pm sent, amba
amba
  • Medway towns
    • German V6
Re: Dis Pack
« Reply #9 on: 30 August 2008, 15:07:57 »
Marks DTM Calib..the miss fire is more than just intermittent but with a big engine the missing seems less noticable than just 4 pots,if you know what I mean.Idle is slightly lumpy but when throttle is "blipped" the miss is quite noticeable.Was advised that wise not to drive as unburnt fuel in bore would start to damage valves..is this correct ??
MutantCav
  • Gainsborough
Re: Dis Pack
« Reply #10 on: 30 August 2008, 19:16:24 »
3 different types...early models 94/95 had a different dispack...than the later models...thought it was all year related though...98 likely to be the same as the dispack on any other 98...
Re: Dis Pack
« Reply #11 on: 30 August 2008, 19:23:00 »
Unburnt fuel will damage the cats long term.
Would be very interested to hear how he tested it as the ECU wont store fault codes for this......and I know that its quite involved to confirm it (having done it myself afew times using Tech2 + some additional test kit).
I assume a few plug leads have been pulled to chek for oil in the plug wells (remember that assumption is the mother of all break ups  :y)
amba
  • Medway towns
    • German V6
Re: Dis Pack
« Reply #12 on: 30 August 2008, 21:00:37 »
Plug lead from each side removed and are bone dry..if not I would be going mad by now as have had both cam covers off and on several times and all leaks are now cured.
He plugged a hand held "omnitech "into the socket by fuse box and it showed a sparking icon which was intermittent with engine running and on the basis that leads and plugs are both new(less than 3k)and car has just returned from 2.5k trip to France,disspack seemed the favourite.
Re: Dis Pack
« Reply #13 on: 30 August 2008, 21:02:37 »
Even more suspicous now as you can get no info about ignition secondaries via teh diag port on the 2.5 and 3.0 V6's.....
The only way to test it is to connect the plug leads to test plugs and fire the sparks individualy via tech 2....
amba
  • Medway towns
    • German V6
Re: Dis Pack
« Reply #14 on: 30 August 2008, 21:07:51 »
Machine was bringing up codes 42/43 and when engine was running it gave a definite "flash and then spark" against each port on the disspack icon with a missed flash every so often..he was certain fault lay with dispack.
