Author Topic: Car seems slugish when starting  (Read 1851 times)
Miggy24
  • Exeter,Devon
« on: 01 September 2008, 16:32:58 »
Hi all as iv been sorting my old mans can of for its mot he has been using mine.i got it back yesterday and now when i start it it seems slugish starting as if the battery aint got much juice.I havent really looked it yet but i looked at the battery and the battery seems fine.Can anyone think of wot else it can be i.e ht leads breaking down etc
Re: Car seems slugish when starting
« Reply #1 on: 01 September 2008, 16:38:05 »
Do you mean not turning over quickly?
Make sure the cable connections are all good and measure the battery voltage with the ignition off and then with the engine running.
If it's turning over ok but not firing or catching very quickly, read the fault codes, it could be early warning of a crank sensor.
Miggy24
  • Exeter,Devon
« Reply #2 on: 01 September 2008, 17:15:00 »
do the 2l 8v engine have the crank sensor fitted
« Reply #3 on: 01 September 2008, 17:16:10 »
Bloody heck an 8V!
I honestly don't know - does it have a mechanical distributor?
Miggy24
  • Exeter,Devon
« Reply #4 on: 01 September 2008, 17:19:04 »
the voltage from what i remember engine off was like 36 and engine was 26 something odd
« Reply #5 on: 01 September 2008, 17:20:36 »
Is your multimeter set correctly, or drunk?
Should be between 12-14!
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #6 on: 01 September 2008, 17:23:49 »
WOT!  I'll assume you mean charging amps!!!! :-/
« Reply #7 on: 01 September 2008, 17:31:56 »
It'd be some multi-meter able to measure that kind of current!  :-?
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #8 on: 01 September 2008, 17:34:22 »
Sorry, was thinking of a clamp measurment :-[
Miggy24
  • Exeter,Devon
« Reply #9 on: 01 September 2008, 18:00:53 »
did the paper clip test it went 2 1 2 then 3 1 3
RobWheatley
  • Lordswood, Chatham, Kent
« Reply #10 on: 01 September 2008, 18:23:34 »
Mine started to be sluggish on the starter, not all the time but every few days or so, then got left stranded in Tesco's car park with a car full of frozen food, I tried all the tricks, hitting it, shorting the terminals etc but total failure of the starter motor, solenoid and the motor failed at the same time!!!!!!  Its auto so couldnt even bump it.
2 1/2 hours later got towed home by the RAC with a boot full of defrosted food  >:(  The stupid controller sent the patrol to Rainham ESSEX, not Kent where i was.
Rob
Miggy24
  • Exeter,Devon
« Reply #11 on: 01 September 2008, 19:55:09 »
What was the prob in the end.Can anyone help me to wot the flashs mean
Pete Elite
  • Uxbridge, Middlesex
« Reply #12 on: 01 September 2008, 20:27:25 »
Miggy24
  • Exeter,Devon
« Reply #13 on: 02 September 2008, 10:32:44 »
right well i did the multi-meter test again and this is what it came up with
Not running 12.8
Running 14.9
« Last Edit: 02 September 2008, 10:42:27 by devonboy2008 »
RobWheatley
« Reply #14 on: 02 September 2008, 13:27:45 »
Voltages seem ok, running is a little high though,  Take the car to a battery supplier and have them do a drop test on it to be sure, only takes a few mins to do.
If the battery passes i would start looking at earth points, battery terminals, starter connections etc, take them off, clean and grease then refit, if its still the same think it will need a new starter motor.
Rob
