Author Topic: Facelift Bonnet  (Read 1107 times)
johnnycboy
  • Colchester
Facelift Bonnet
« on: 02 September 2008, 13:47:28 »
When I close the bonnet it latches but you can still push down about 10mm even though its locked close.  Is there a way to adjust the closing mechanism.
tia
razzo
  • Crapital
    • 97 3.0 Elite
Re: Facelift Bonnet
« Reply #1 on: 02 September 2008, 15:12:45 »
I think there is a locking nut on the striker on the bonnet if you loosen the nut & screw the striker in a bit at a time should sort it
unlucky alf
  • worksop, notts
Re: Facelift Bonnet
« Reply #2 on: 02 September 2008, 15:20:18 »
just like to add to that, make sure the catch is fairly free from rust etc & put a coat of grease on it, otherwise itll shut really snug but pulling the bonnet release might be a problem, if that happens get somebody to push on the nose of the bonnet while you pull the release then re-adjust.
johnnycboy
  • Colchester
Re: Facelift Bonnet
« Reply #3 on: 02 September 2008, 15:57:07 »
thanks lads will give it a whirl when home from work thursday. :y
