Author Topic: Autobox question  (Read 1785 times)
johnnycboy
  • Colchester
Autobox question
« on: 02 September 2008, 13:26:37 »
Just found this about a brake band on the gearbox
"when the sump is removed there is a dome held on with three bolts this is removed and there is a screw with a lock nut the nut is released then the screw is tightened to a set torque and backed off five turns and locked off at that, this sets the brake band. replace dome, replace screen(filter), refill sump, refit sump (carefully) run up to op tempreture and then remove the level plug to drain the excess oil out (the oil must be at or above set temp) "
Anybody heard this before :question
Beconboy
  • DAGENHAM
    • 2000 3.0 OMEGA ELITE
Re: Autobox question
« Reply #1 on: 02 September 2008, 13:44:18 »
got it soughted then john?
johnnycboy
  • Colchester
« Reply #2 on: 02 September 2008, 13:49:43 »
[/highlight]
Not heard a dickie bird yet :exclamation
Think its gonna be a real pain in the harris >:(
Beconboy
  • DAGENHAM
« Reply #3 on: 02 September 2008, 13:55:57 »
typical john .Wish ya luck m8 :y
sassanach
  • trowbridge
« Reply #4 on: 02 September 2008, 17:20:48 »
what exactly are you trying to achieve?
johnnycboy
  • Colchester
« Reply #5 on: 02 September 2008, 17:39:06 »
[/highlight]
I'm not trying to achieve anything - this is just some thing i came across whilst surfing the big wide web, just wondered if anyone else knows what it means, according to the place i found it this should be adjusted with each fluid change :-/.
sassanach
  • trowbridge
« Reply #6 on: 02 September 2008, 18:03:25 »
news to me. :)
unlucky alf
  • worksop, notts
« Reply #7 on: 02 September 2008, 20:03:20 »
isnt it also in the haynes book of fairy stories??, im sure i read it whilst trying to sort mine out. :)
Big_Al
« Reply #8 on: 02 September 2008, 20:27:06 »
Johnny boy - Basic rule ! -- Don't mess around inside AUTO boxes -
Specialist stuff - I have heard about brake band adjustments years ago -  but can't remember what it's all about.
Iirc  I had an old ford Granada that the Auto box specialist said need the brake bands adjusted -- it was never the same after that was done.
My advice -- LEAVE WELL ALONE ! :o :o :o
« Last Edit: 02 September 2008, 20:27:42 by Big_Al »
johnnycboy
  • Colchester
« Reply #9 on: 02 September 2008, 21:28:45 »
I have enough problems to deal with without creating anymore.  point taken
