Author Topic: fault code  (Read 1194 times)
rikki_essex
  • essex
    • 2L gls estate with lpg 20
fault code
« on: 02 September 2008, 14:44:49 »
i know this is probably not a fault code but the light with the spanner on it just keeps flashing when the brake and accelarator pedal test is done any ideas????
regards Rik
Re: fault code
« Reply #1 on: 02 September 2008, 17:16:32 »
Continuous flashing under that test means no codes stored  :y :y :y
HTH
Re: fault code
« Reply #2 on: 02 September 2008, 21:52:35 »
good news, no engine codes stored. Only reads engine ecu. Where you just curious or is something up?
rikki_essex
  • essex
Re: fault code
« Reply #3 on: 03 September 2008, 07:16:54 »
just curious mate i had a crank sensor fault and was wondering if it had gone obviously it has cheers fellas
regards Rik
