Author Topic: Cam Cover Sealant  (Read 3700 times)
Alex W
    • 2000W Facelift 2.5V6 Elit
Cam Cover Sealant
« on: 02 September 2008, 20:26:37 »
I went to the Vauxhall dealer to order the parts needed to replace cam cover gaskets on my 2.5 V6 as listed in the Maintenance Guides.
The guide specifies sealant Part No 90485241, but the spotty child at the counter said "Computer says 'No'". No such part number and they even went so far as to say that I didn't need sealant at all (that was a guy from the service dept.).
However, I told them that sealant is clearly shown in the Haynes Manual and also on this auspicious forum.
The upshot was that I couldn't have the part no specified but they offered me  Sealing Compund Part No. 93165267 instead. £8.15 + VAT.
My question is : Does anyone know if this replacement stuff is OK for the job or not? I don't think the Vauxhall child had any clue what he was selling.
Thanks in advance for any help offered. :)
Black cxd v6
  • Germany
Re: Cam Cover Sealant
« Reply #1 on: 02 September 2008, 20:30:09 »
I used silioset of my old vectra its white but works up to very high temps.
Big_Al
« Reply #2 on: 02 September 2008, 20:31:17 »
I understand that there are two types - Black & Green I think.
It must be the Black stuff & it MUST be used.
Had no trouble getting it here in Southend
Someone will be along and give you full details soon.
regards, AL
« Last Edit: 02 September 2008, 20:32:01 by Big_Al »
Dazzler
  • Haverhill, Suffolk
« Reply #3 on: 02 September 2008, 20:32:50 »
I believe the sealing compound is the Grey stuff........do not use this.
This is just typical Vx at times.
The black stuff does exist.
You can use an aftermarket one, such as Loctite or similar. It is still black and specifies its use for gaskets etc.......
sophos9
  • Norfolk
« Reply #4 on: 02 September 2008, 20:38:11 »
Part number should be 90542114, SEALING COMPOUND...
Get the Vx stuff!
« Last Edit: 02 September 2008, 20:38:41 by sophos9 »
    • 530D M Sport, 330i Coupe
« Reply #5 on: 02 September 2008, 20:42:26 »
Or use Loctite 900 which is what they used at the factory.
Dazzler
« Reply #6 on: 02 September 2008, 20:47:34 »
Thats the one i was trying to think of :y
trebor
  • Swindon
« Reply #7 on: 02 September 2008, 21:00:20 »
I too was told not to use any sealing compound by the dealer.
I haven't and all I did was make sure head surface and cam cover surface were spotless.
I have no leaks what so ever.
sophos9
  • Norfolk
« Reply #8 on: 02 September 2008, 21:02:27 »
Sorry but they talk out of their arse. Even the TIS informs the muppets to do it. The half moons will leak, maybe not today but...
hotel21
  • The Kingdom of Fife
« Reply #9 on: 02 September 2008, 21:03:56 »
Some of the drones who occupy the parts counters etc at VX dealers are simply wage takers.  If the magic box says no (or they think that they know better) you are on a hiding to nothing.
Personally, if a howtoo guide on here composed by Marks_DTM said its there and should be used, I would take no alternative....   :y
sev
« Reply #10 on: 02 September 2008, 21:39:02 »
You can get away with not useing the sealer, but as has already been said, there will come a time...
The sealer is there as an insurance when the gasket goes round angular faces.
You have to remember that the heads are not precision machined, they are just skimmed flat to a known good tolerance that is all.
Now if the cam cover is also made to same tolerance there's no guarantee that all surfaces will mate as per the CAD model now is there!
The idea of the sealant is that it takes up any deviation when the seal does not sit on a flat surface or goes around a radius, that way you know for certain that you have a contact on those tight male and female angles.  In an ideal world you'd have everything machined to within 0.01mm and the seals would be .2 or .5 oversize, but this isn't racecars, it's production cars, and in the grand scheme of things, it probably saved .5p per seal if it wasn't any bigger than what was required to do the job.
Also remember that the rear of the engine is also a pig to get to, and difficult to check to see you have proper mates of all the surfaces.
So please... with a cherry on top... use the sealant!
Why not buy the Cam cover gasket kit from the OOF shop? - it contains all that you need, and a tube of sealant - and weighs in very cheap considering that you don't have to deal with knuckle draggers  :y
1995 2.5 V6 CDX Saloon
« Reply #11 on: 02 September 2008, 21:44:52 »
There out of stock, but all the correct part No's are there ;)
iainb
  • West Midlands
« Reply #12 on: 02 September 2008, 22:08:27 »
All I used was a smear of grease in the cover channel, that was to hold the new gasket in place I also used a splodge on each ring to hold them and it didnt and hasnt leaked
sophos9
  • Norfolk
« Reply #13 on: 02 September 2008, 22:29:19 »
Personally, if I had not used sealant I would be worrying about not if, but when they let go!! All the instructions and technical systems state using sealant for a reason!
As soon as there is any shrinkage in the gasket, you gonna unhappy  :-X  :'(
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #14 on: 02 September 2008, 23:16:35 »
Try asking for 90485251 COMPOUND, SEALING, 50ML, OIL LEAK SEALANT
not 90485241 which is a steering wheel impact absorber for a corsa.
TuBy's new whipping boy.
