Author Topic: Stalling on Idle with Climate Off  (Read 3514 times)
sophos9
  • Norfolk
« on: 02 September 2008, 11:22:04 »
Hi,
I've noticed that my 97 3.0 has started stalling when the climate control is off. Revs with climate on is approx 600, when off approx 400rpm...
At idle, the revs are very steady, no hunting or surging of revs. Vacuum pipes are all correct (as to Marks drawings), no air leaks (which I would presume would cause hunting revs).
The stalling only happens on idle, not at any other time (cranks sensor changed approx yr ago).
Breathers are all clean, TB's are clean too (oil changes between 5-8k  :y )
I'm presuming ICV, any thoughts please?
hotel21
  • The Kingdom of Fife
Re: Stalling on Idle with Climate Off
« Reply #1 on: 02 September 2008, 11:29:59 »
Given the ease of removing and cleaning the Idle Control valve with copous carb cleaner, I would do the deed.  Then lubricate with a couple of drops of light sewing machine oil or 3 in 1 (NOT engine oil) and refit.  See if its still the same and advise back.... :y
« Last Edit: 02 September 2008, 11:30:40 by hotel21 »
sophos9
  • Norfolk
« Reply #2 on: 02 September 2008, 11:32:09 »
Cheers mate,
Just to refresh, does the plenum need to come off to remove the ICV on the V6?
hotel21
« Reply #3 on: 02 September 2008, 11:34:21 »
Cheers mate,
No.
ICV is on front RHS of plenum as you face the engine from the front.  Remove hoseclip with screwdriver, remove electrical connector then ICV pulls out the plenum.  There is a guide and/or usefull engine piccy, will race you to find it!   ;D
sophos9
  • Norfolk
« Reply #4 on: 02 September 2008, 11:36:46 »
Thanks,
Just remember mine having part of the rubber connector bolted to the underside of the plenum?
hotel21
« Reply #5 on: 02 September 2008, 11:37:38 »
Most of them are now broken free from the plenum, no probs....
sophos9
  • Norfolk
« Reply #6 on: 02 September 2008, 11:37:40 »
This the pic?
hotel21
« Reply #7 on: 02 September 2008, 11:38:40 »
Nope, its this one....
http://www.omegaowners.com/forum/YaBB.pl?num=1189893355
its the gubbins nearest the oil filler cap as you are looking at it....
If the hose and electrical connector is removed, there is enough slack in the large rubber circular mount that you can remove the part from the plenum then pull it free from the rubber mount.
« Last Edit: 02 September 2008, 11:40:10 by hotel21 »
sophos9
  • Norfolk
« Reply #8 on: 02 September 2008, 11:38:52 »
Ahh, I replaced mine about a year ago  :y
sophos9
  • Norfolk
« Reply #9 on: 02 September 2008, 11:40:39 »
Will have it off and clean it up!
Cheers...
hotel21
« Reply #10 on: 02 September 2008, 11:53:37 »
Remember to put NOTHING down the slot other than carb cleaner/drops of oil when finished.  Do not be tempted to use a screwdriver or blade in there....  Give it a good long fill of cleaner, cover both in/out pipes with the fingers and give it a bloody good shake around for a while.  Empty and repeat several times, then a fwe drops of oil.
sophos9
  • Norfolk
« Reply #11 on: 02 September 2008, 12:02:19 »
Thanks. Also think I need to sort a new pipe that goes from the multiram to the ICV then spurs off and goes to the fuel rail.
This one has started to perish on the spur...
« Reply #12 on: 02 September 2008, 13:06:18 »
Very sound advice... I thought I'd give it a good scrape out and ended up getting a replacement unit :-[ :-[ :-[ :-[ :-[
sophos9
  • Norfolk
« Reply #13 on: 02 September 2008, 13:22:22 »
DOH! Bet that hurt  ;D
« Reply #14 on: 02 September 2008, 13:37:43 »
Hurt the pride more than anything else!!! Luckily I managed to get a replacement from a member here who trusted me enough to get it in the post to me before I'd even paid him :o :o :y :y
Top work Dan... Thanks :y :y :y :y :y :y
Page created in 0.076 seconds with 16 queries.
