Author Topic: Misfire and/or violent judder  (Read 2721 times)
gwa
  • Peterborough
  • Ginger With Attitude
« on: 01 September 2008, 21:35:56 »
I've been talking via PM's to TheBoy and he advised me to post the following:
Symptoms:
I have a 2001 Omega 2.6 CD V6 which appears to be misfiring.  I currently work in Biscester [80 miles] (Nr Oxford).The journey to work this morning was OK, but I struggled home tonight with lots of misfiring. Its very intermittent though, but appears to come when the engine is hot.
Fault codes: (press both pedals, turn ign to II, and count flash sequence), and also check plug wells for oil
There was flashes in the following order:
1
7
10
10
Whilst driving the gearbox feels as sweet as nut, but when the problem happens it sounds like a misfire. Having said that, the gear stick goes mental with vibration but then it would appear the engine is as well [There is no oil in the wells]. Its intermittent though I leave home (P'boro) at 05:30 and all is really smooth and going well, by the time I get to Brackley [65 miles] the engine light may flash or even stay on and the 'misfire' starts to occur. Any ideas? What else can I check? Any help will be greatly appreciated. :'(
If it ain't fun, it ain't worth doin
Re: Misfire and/or violent judder
« Reply #1 on: 01 September 2008, 21:49:50 »
1700 is a code meaning gearbox not happy, as discussed.  Probably unrelated to misfire.
2.6 ecu normally stores codes for misfires, which is why I'm at a bit of a loss on this one...
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #2 on: 02 September 2008, 00:07:29 »
Does it misfire at a certain engine speed?
Just asking as the knackered crank sensor on my 2.5 produced a juddering above 5K rpm, in effect it was banging off the rev limiter and juddering like a good un but disappeared if I came off the gas.
Mine was flagging up an incorrect crank signal though.
TuBy's new whipping boy.
« Reply #3 on: 02 September 2008, 01:22:26 »
Hi GWA welcome to the forum. Strange one this, engine light comes on but no fault code stored. hang on i thought the pedal trick only read the engine ecu? Hows it read a gearbox code?is that the right number? Or is that a non specific engine code? Bit beyond me by the sound of it. Hes driving past your Door J?
gwa
  • Peterborough
« Reply #4 on: 02 September 2008, 07:31:56 »
Its not really associated to speed although when it happens if I hit the 'Sport' button to increase the revs it calms down a bit. Also, if I stop the car and switch off then restart everything appears to go back to normal, sometimes for a long time sometimes not. Then all of a sudden, one morning the engine light will be out and for a week or so it'll be fine. I think my Omega is female and suffering PMT.  ;D
gwa
  • Peterborough
« Reply #5 on: 02 September 2008, 07:40:24 »
Thanks for the welcome. Yes it is weird cos its intermittent. My local non-Vx garage put their diag box on it and there were loads of codes and he said take it to Vx, one was all about multiple misfires another about the ecu and the list went on. I'm wondering if I have mulitple issues that are causing confusion!! I need to save up and take it to Vx or buy a 12 bore and shoot the bl00dy thing  :'(.
« Reply #6 on: 02 September 2008, 09:17:09 »
the 12 bore option would be cheaper and more usefull than taking it to a vx dealer. Although there are a couple good ones about. Maybe someone will know a good one out your way. But if your near brackkey or notingham at any point there are a couple of tech 2 members there. The Boy being one of them. Hes got to be your best bet tbh. Ecu plugs ok, no corrosion or damp in the plug?
The multiple miss fire code and others your local mech found, did he clear those ? And you did the pedal trick after the codes where cleared?
« Reply #7 on: 02 September 2008, 09:34:19 »
Flashing emissions light (one with the engine symbol) indicates a fault that could cause the cats to be damaged so if it flashes, ease off thwe throttle until it stops flashing.
I wonder if some stored codes are not being flashed out. I would get a cheapo Tech 2 and read all the codes. I'm sure it will have stored some codes. My guess is either crank sensor on its' way out or a faulty coil pack / plugs. (when were the plugs last changed?)
Gearbox fault is probably a consequence of the gearbox ecu not receiving a stable RPM signal from the engine ECU. That points to crank sensor again, IMHO but get the codes read properly or have another go at flashing them out and all will be revealed.
gwa
  • Peterborough
« Reply #8 on: 02 September 2008, 09:54:22 »
Thanks Kevin/chrisgixer. I'll get back onto TheBoy and see when its convenient to pass through. Really appreciate it, thanks again. Errrm, is that crank sensor an expensive job?
« Reply #9 on: 02 September 2008, 11:14:11 »
not too bad, 2 sorts iirc 30 odd and 60 odd, or something like.easy diy they say. how long have you had this problem? In my experience, aftera week of general use they usually fail. which could happen while driving, cause engine to cut out and loosing power steering p ass brakes, not safe, others will advise but you "may" wish to change it anyway, at least if its not that you will have a spare. hope helps :-/
gwa
  • Peterborough
« Reply #10 on: 02 September 2008, 12:03:46 »
Ah, thats not going to break the bank... I've had the car for about a month but total driving has been about 500-600 miles as I tend to spread my mileage across 3 cars. I will however, get this little jobby done pronto. Thanks
« Reply #11 on: 03 September 2008, 10:00:30 »
Right, so there were more codes that the pedal trick flashed out?
Best pop it by one day, and we'll clear out everything, then you run for a couple of days, and we'll see whats come back.
« Reply #12 on: 03 September 2008, 10:32:46 »
Hmmm....I would be checking the condition of the coil packs and looking for cracks/corrosion around the iron cores.
« Reply #13 on: 03 September 2008, 10:42:29 »
Morning Mark, had presumed that would have been visible when he checked the wells for oil?  any signs gwa? :-/
gwa
  • Peterborough
« Reply #14 on: 03 September 2008, 10:45:06 »
Thanks. I'm in the wifes Corsa today, but if you can do it tomorrow that would be great as I can give it a outing over the w/e. If not suggest another date and PM me your details.
What are iron cores?
