Author Topic: Climate Control not working  (Read 1048 times)
Minstrel
« on: 04 September 2008, 10:00:51 »
I have an R-reg Omega 2.5 V6 CDX and the climate control doesn't seem to work properly. If I set the temp low, it only blows cold when the car is moving at speed. Also, no matter what blower settings I select, the air always comes out the front vents and footwell vents. I can't get the air to blow out of the windscren vents or the rear pasenger vents.
Any ideas?
Re: Climate Control not working
« Reply #1 on: 04 September 2008, 10:17:00 »
Not sure about your exact problem but try re setting the vents, hold off and auto for 10 seconds.
Or check the vac pipe in well located on top of the hbv. The vents are vacume operated as i understand it so might be an idea to check the vac system for leaks and connections"might". Guide in maintenance section.
Minstrel
« Reply #2 on: 04 September 2008, 10:24:08 »
Thanks for that - I'll give it a go later today
