Author Topic: Alarm and horn sounder Going off  (Read 1016 times)
MarkG
  • Northwich, Cheshire
  • "An Omega? Been a while since I saw one of those!"
    • 2000 CD 2.5 V6
« on: 07 September 2008, 00:07:44 »
I have just been interupted from Quadraphinia twice by my car's alarm. I only ever lock it with one blip from the keyfob so I assumed I was not arming the alarm. But it's gone off twice in 30 mins. I guess the alalrm battery is low? How do I disable it?. Thanks. Mark
Bandit127
Re: Alarm and horn sounder Going off
« Reply #1 on: 07 September 2008, 00:12:33 »
Try locking the car with the key in the door lock, rather than with the blipper.
(And double check your windows and sunroof are closed, obvious tough that seems).
« Reply #2 on: 07 September 2008, 00:29:48 »
favourites for false alarms are bonnet switch, bend the bracket up a bit so makes more contact and is compressed a bit more, if no good either tape it down or disconnect altogether to eliminate it as it could also be the power sounder under the scuttle drivers side. It has a built in battery that can be low or leaking which can set it off, sometimes even while driving. Hth.
