Author Topic: Red Tap on Radiator Drain  (Read 1978 times)
MarkG
  • Northwich, Cheshire
  • "An Omega? Been a while since I saw one of those!"
    • 2000 CD 2.5 V6
« on: 06 September 2008, 22:04:07 »
Is the red tap supposed to screw right out of the bottom of the radiator? I changed my coolant today and could loosen the red plug to drain OK, but not pull it right out. Now it is tightened back up again, I have a slight leak from it. So I was thinking I need a new one
hotel21
  • The Kingdom of Fife
Re: Red Tap on Radiator Drain
« Reply #1 on: 06 September 2008, 22:11:37 »
It does not come out completely, or should not.  It comes off the thread but does not come off the mount, if that makes sense.
It should nip up OK but would suggest that you do not overtighten as once the threads strip, could be a new radiator repar, despite the red bit being softer than the radiator itself....
« Reply #2 on: 06 September 2008, 22:17:24 »
Tightening the red tap doesn't make the seal. There are 2 'O' rings on the tap that make the seal so you're only tightening it up enough to prevent it from vibrating out of the rad.
You could try removing it again & checking you've not damaged an 'O' ring.
MarkG
    • 2000 CD 2.5 V6
« Reply #3 on: 06 September 2008, 22:18:34 »
Is it supposed to have a rubber O ring?
stuthespread
  • stevenage,herts
  • no spring chicken
« Reply #4 on: 06 September 2008, 22:18:37 »
why not try a bit of ptfe tape on the thread,works a treat on most of my plumbing jobs.
« Reply #5 on: 06 September 2008, 22:26:55 »
As above .... it has 2
« Reply #6 on: 06 September 2008, 22:27:31 »
 ..... it doesn't seal on the thread! ;)
stuthespread
  • stevenage,herts
  • no spring chicken
« Reply #7 on: 06 September 2008, 22:29:29 »
if the threads been stripped it'll work a treat.
« Reply #8 on: 06 September 2008, 22:31:56 »
Yes! It'll help restore the thread, but as for sealing the water/coolant, it shouldn't get as far as the thread. :y
« Reply #9 on: 06 September 2008, 22:33:07 »
I knew I had one somewhere.  ;)
MarkG
    • 2000 CD 2.5 V6
« Reply #10 on: 07 September 2008, 10:58:00 »
Ahhh. So it should come out so I can chnage the seal sif I can just  squeeze the two end prongs?
JasonH
« Reply #11 on: 07 September 2008, 15:28:59 »
I think it's only a couple of quid for a new tap with the o-rings.
Just need to tug the old one out.
