Author Topic: Miss fire  (Read 1847 times)
iainb
  • West Midlands
Miss fire
« on: 08 September 2008, 14:03:47 »
Changed HBV found evedence of a water leak so I was happy. During my test drive it started missing below 2000 prm and poured water out again,although there is pressure in the expansion tank. Add to that the mil light is on all the time and I think the cats are burning up (strong smell )
Any ideas ?
Re: Miss fire
« Reply #1 on: 08 September 2008, 14:05:39 »
Smell could be coolant leaking onto the cats
Can you paperclip test, and post up the fault codes?
Where is the new leak, if you've replaced HBV? Is it over pressuring?
If HBV was leaking beforehand, it could have killed DIS pack, or drenched the 1-3-5 plug leads... resulting in misfires.
iainb
  • West Midlands
Re: Miss fire
« Reply #2 on: 08 September 2008, 14:42:47 »
codes
 12
31
32
33
iainb
  • West Midlands
Re: Miss fire
« Reply #3 on: 08 September 2008, 22:13:56 »
Update its now running rough up to 2300rpm and is very hard to start. over 2500rpm she's sweet.
Ive done something to her but cant what................
Re: Miss fire
« Reply #4 on: 09 September 2008, 00:04:31 »
12 means nothing, it just tells you it's starting to flash out codes.
31 is normal without the engine running - don't worry about it in the slightest.
32 is  Injector Valve 6 Voltage High
33 is  Exhaust Gas Recirculation (EGR) Valve Voltage Low
I would start by giving the EGR valve a good clean out. Mark recommends paint thinners, from memory.
See what happens after that.
It helps to have a cheapo Tech2 to clear the codes, to see which are non - present..
iainb
  • West Midlands
Re: Miss fire
« Reply #5 on: 09 September 2008, 16:25:37 »
How many leaks can one car have. Ive got water in the valley now, V pipe leaking, Im going to pay the guy to do it as its persisting down rain and I aint got no garage.
