Author Topic: Plug lead change  (Read 1661 times)
BobF
  • Banbury
Plug lead change
« on: 09 September 2008, 19:21:41 »
Hi, I am going to change the plug leads on my 2000 v6 omega. It looks a bit crowded at the back after taking of the scuttle. I would like some advice as to what needs to be taken off (if anything) to get at the DIS. Thanks
Eliteman Steve
  • Brighton
Re: Plug lead change
« Reply #1 on: 09 September 2008, 19:34:12 »
removing the plenum chamber from top of engine may give you a bit more room to manouvre , just keep all 'o' rings and plug holes with paper towel so nothing drops into engine.
« Reply #2 on: 09 September 2008, 19:40:07 »
have a look here, always wortha look through the guides :y
http://www.omegaowners.com/forum/YaBB.pl?num=1155224533
« Reply #3 on: 09 September 2008, 19:55:59 »
i have seen a guide showing the layout of the plug leads and thier position on the dis pac but i cant find it, its real easy to get it wrong  and plug the lead in to the wrong position on the dis. i did my old car and it was a job done by feal!!!
hopefully you can work it out from the dis change guide above.hth :-/
Timbuk
  • Telford
  • owned a Datsun 120y once!
« Reply #4 on: 09 September 2008, 20:02:21 »
Try this ;)
Numbers are on the dis pack too
« Last Edit: 09 September 2008, 20:03:58 by Timbuk »
BobF
  • Banbury
« Reply #5 on: 09 September 2008, 20:03:45 »
Thanks for the replies, I will have a go tomorrow, if it stops raining that is!
