Author Topic: No main beam  (Read 1308 times)
capoMV6
No main beam
« on: 09 September 2008, 15:12:59 »
Now I need your advise.  I only have dipped beam on my headlights. All other lights are ok i.e. signal lights, hazzard, fog lamps and dipped beam.  Checked every fuse, bulb and even replaced switch but to no avail.  Blue indicator on dash is also out. What could be the problem. Appreciate you help. Thanks.
Re: No main beam
« Reply #1 on: 09 September 2008, 15:14:46 »
IIRC there is a LARGE fuse (80 Amp ??) that does both the headlights in the box beside the battery ??  Might be that one ..
markey mark
  • SLady bitshorpe north lincs
Re: No main beam
« Reply #2 on: 09 September 2008, 15:59:28 »
could be your switch matey  :y
capoMV6
Re: No main beam
« Reply #3 on: 09 September 2008, 16:10:49 »
Nope. Alredy tried replacing the switch. Still no good.
markey mark
Re: No main beam
« Reply #4 on: 09 September 2008, 16:39:30 »
what about the main switch not just the stalk  :-/
Re: No main beam
« Reply #5 on: 09 September 2008, 21:35:42 »
I'll stand back and wait to be corrected but... Isn't there a relay for main beam too? Can't check because I'm at work but just a thought! :-/ :-/ :-/
