Author Topic: Fuse for Horn keeps blowing...  (Read 1128 times)
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
« on: 10 September 2008, 20:04:50 »
Just replaced the fuse again, horn worked for 2 plips, then it blew again.
Anything else running on this circuit or is the horn the only thing off the fuse?
Suppose its worthwhile just changing the horn over if thats the case and trying that yeah?
Humbugs...
Re: Fuse for Horn keeps blowing...
« Reply #1 on: 10 September 2008, 21:25:14 »
Do both horns work? I've just had this with my Astra, but only one was working. I disconnected the horn that didn't work & the fuse stopped blowing. A new 500Hz horn was a little over £20 fro a new one.
« Reply #2 on: 10 September 2008, 21:26:58 »
Often sign one of the horns failing
PaulW
« Reply #3 on: 10 September 2008, 21:36:01 »
nah it sounded quite flat compared to normal, so probably on its way after drowning in water at Newent
I'll get another one ordered and fitted then cheers  :y
Humbugs...
« Reply #4 on: 10 September 2008, 21:41:04 »
Get one from scrapper
« Reply #5 on: 10 September 2008, 22:43:41 »
Had the same on the saloon - faulty horn(s).  Try markey mark on here for replacement horns - cured mine.
« Last Edit: 10 September 2008, 22:45:51 by dbug »
