Author Topic: misfire under load  (Read 764 times)
tigerwoods
  • wandsworth london
misfire under load
« on: 11 September 2008, 18:17:48 »
wondered if anyone can help my sick cdx 2.6? recently developed a misfire at low revs under load in all gears but mainly pulling away from a standstill, i put in new plugs but i think it may have all started after i took off at high revs oneday and the engine management light came on for a few minutes and the engine ran like a bucking bronco for a couple of miles! misfires as described eversince!
  any ideas would be greatly appreiciated.  :y
Dazzler
  • Haverhill, Suffolk
Re: misfire under load
« Reply #1 on: 11 September 2008, 18:23:17 »
Needs to be code read to see what has been stored, otherwise its just guessing which costs the pocket....lol
« Reply #2 on: 11 September 2008, 18:59:54 »
Check for fault codes, if none, suspect coil pack or electronic throttle on that unit.
The fact you changed plugs before it happened, retrace steps, ensuring coil pack fully seated.
