Author Topic: coil pack  (Read 3568 times)
prr
  • paignton devon
  • dont be scared to take it apart
coil pack
« on: 07 September 2008, 17:18:51 »
hi all got a problem with my 2l no spark on two plugs have taken coil pack out is there any test with meters you can do to see if its failed it was running fine then started to miss fire any clues thanxs
Re: coil pack
« Reply #1 on: 07 September 2008, 17:36:36 »
I dont know of any home test,might be worth swapping with one from a scrappy or similar to see if it cures the problem. :-/
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
Re: coil pack
« Reply #2 on: 07 September 2008, 17:50:44 »
Is the EML on, any stored codes?
Trade club card holder
Code scanner available
prr
  • paignton devon
Re: coil pack
« Reply #3 on: 07 September 2008, 18:47:04 »
no eml on just a miss fire new plugs and leads a few months ago
prr
  • paignton devon
Re: coil pack
« Reply #4 on: 07 September 2008, 21:44:25 »
well its to dark now but ive put it back togehter and it still runs lumpy but ive got no eml on if you pick up the revs quite high it seems run ok as soon as they die of to tick over it goes all lumpy again  :'(
alexandjen
  • The Silver Surfer
Re: coil pack
« Reply #5 on: 07 September 2008, 21:57:22 »
Have you checked the plug wells for water/oil?
prr
  • paignton devon
Re: coil pack
« Reply #6 on: 07 September 2008, 22:01:46 »
yes no oil or water in the wells but ive got no spark on the 1st plug (nearest the dis pac) and the 4th (nearest the cams) ive checked for water in all connections as i wash jetwashing it today but was careful not to go across the top of the engine dis pack area  :'(
Re: coil pack
« Reply #7 on: 07 September 2008, 23:10:16 »
try swapping a good lead onto bad cylinder if it will reach and see if it sparks. If it sparks no1 lead buggerd. If not chance dis pac. While your in there, you may want to clean the idle control valve and breathers if you havent already. Wont hurt to clean cam sensor and do a paper clip test. Hth
Re: coil pack
« Reply #8 on: 07 September 2008, 23:20:20 »
That is exactly the symptoms, with lumpy acceleration till higher revs, I had, replaced the rocker gasket, as oil in plug holes, new plugs and leads, still a missfire.
Fitted a new coil pack, bought from ebay, and all is fine.
Not too difcult a job if you have skinny arms and hands. ::)
prr
  • paignton devon
Re: coil pack
« Reply #9 on: 08 September 2008, 18:17:20 »
can you have a problem with the coil pack but no eml on
Re: coil pack
« Reply #10 on: 08 September 2008, 18:24:43 »
yes.
and fact its 2 cylinders down, likely to be dis....
Re: coil pack
« Reply #11 on: 08 September 2008, 22:53:35 »
Yes, I did. ::)
philhoward
  • Staffs
  • Love the engines, so put one in something else..
Re: coil pack
« Reply #12 on: 08 September 2008, 23:27:32 »
I have a spare with leads if needed - working when removed.
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
amba
  • Medway towns
    • German V6
Re: coil pack
« Reply #13 on: 09 September 2008, 09:03:54 »
Had similar problems with mine.Very lumpy and had no acceleration,but no EML .Had replaced all leads and plugs about 3 months before..managade to get a replacement from JueV6 and now runs a treat.Just be carefull as disppack comes in 3 types with different plug connecter..oval/rectangularon end /rectangular on side but that seems to be for older<97 models.
philhoward
  • Staffs
Re: coil pack
« Reply #14 on: 09 September 2008, 19:50:16 »
This one's off a 95/N..can check connector if needed?
