Author Topic: Difficult to get in gear from neutral  (Read 2538 times)
matt-sboro
  • scarborough
« on: 11 September 2008, 10:20:04 »
as title - if i try to get in gear from neutral then it takes a nit more effort than it should.
its fine when driving and i change gear but its if i put it into nuetral and then try and put it back into gear from there.
any ideas? gear box fluid?
Re: Difficult to get in gear from neutral
« Reply #1 on: 11 September 2008, 10:24:00 »
Possibly a dragging clutch ?? or an incorrectly adjusted selector ??
Manual box the fluid is doing nothing when stationary, so I doubt fluid level has much to do with it.
« Reply #2 on: 11 September 2008, 10:30:18 »
Bleed the hydraulics first.
The Barge Captain
« Reply #3 on: 11 September 2008, 13:18:50 »
Mine is doing the same.
I suspect there is a weak / broken spring on the pressure plate
jimmas
  • stevenage, herts
« Reply #4 on: 11 September 2008, 13:41:42 »
Agree sounds like a weak pressure pate, does it drag when going into reverse.
matt-sboro
  • scarborough
« Reply #5 on: 11 September 2008, 14:15:15 »
what do you mean by drag?
its not been too bad today but some days you really have to force it in sometimes
jimmas
  • stevenage, herts
« Reply #6 on: 11 September 2008, 14:17:22 »
sorry mate, does it crunch when going into reverse
matt-sboro
  • scarborough
« Reply #7 on: 11 September 2008, 14:29:26 »
no - doesnt crunch, just takes more effort than it should do to get in gear.
as i said before - its perfect when driving
Matchless
  • Nottingham
    • A white van
« Reply #8 on: 11 September 2008, 14:46:29 »
It wont 'crunch' when selecting reverse as there is a form of synchromesh on reverse.
It sounds like a dragging clutch which could be caused by:
Air in hydraulics
Oil contamination of friction surfaces
Dry grease on input shaft splines
Cracked or broken pressure plate spring
So bleed the hydraulics first ( from bottom up, look at my how-to on auto to manual conversion), everything else requires the gearbox to be removed.
tomoco
  • leicester
« Reply #9 on: 11 September 2008, 23:07:57 »
I have similar probs with my car. but not as bad and only when the gearbox is cold. going to do a gearbox flush and oil change soon (when the car gets a day off) just to see if it makes any difference.
Think i'll attempt a full hydraulic flush out (brakes and clutch) Dont fancy dropping the gearbox out unless i have no choice. Had the car for 18 months and the problem has always been there, and it has'nt got any worse
« Reply #10 on: 12 September 2008, 00:15:33 »
Flush the oil and bleed the hydraulics first, both easy jobs.
If you do have to drop the box, it really is a peice of cake :y
