Author Topic: wanting some advice guys&gals please  (Read 1448 times)
Tony16v
  • merseyside
« on: 10 September 2008, 23:42:56 »
i own a 2ltr 16v mk2 omega on a P reg auto
i have just serviced the car about a month ago but i keep getting oil light warnings on the dash one of the just says "Oil Lack" and " Engine oil low"
how can this be when its just been serviced?
Also it keep popping out of Drive?? so i have to hold the gear stick in position, then the other day a message came up on the dash saying "Automatic Gearbox"
so at this point i am confused
thanks in advance
Tony
P.s  anyone got a lamba sensor for sale
We can supply you with heat pressed or embroidered garments,
caps, workwear, banners, plastic/card business cards,
aboards, vehicle magnetics, car/van signage, vinyl lettering
Re: wanting some advice guys&gals please
« Reply #1 on: 10 September 2008, 23:51:47 »
I have to ask the obvious but... Have you physically checked the oil level and for a leak from either the sump or filter ::) ::)
Tony16v
  • merseyside
« Reply #2 on: 10 September 2008, 23:58:07 »
checked both no leaks
« Reply #3 on: 11 September 2008, 00:01:08 »
Faulty low oil level switch or wiring to it is goosed then.  ;)
« Reply #4 on: 11 September 2008, 00:53:27 »
Gearbox shouldn't be limping - I'd suggest checking ATF and reading fault codes, and going from there.
If you say it pops out of drive - you mean revs increase, but car doesn't go anywhere?  :-X
Tony16v
  • merseyside
« Reply #5 on: 11 September 2008, 21:19:41 »
thats correct then i have to pull over switch off and shift the stick to 3 and drive off, but after a few days its back to normal and everything is ok :-/
philhoward
  • Staffs
  • Love the engines, so put one in something else..
« Reply #6 on: 11 September 2008, 23:45:54 »
Reading the saga - is there some slack in the gear linkage - i.e. you can rock the lever fore and aft a little whilst in D?  Mine was a little "loose" - turned out to be the nut holding the linkage onto the gearbox was about to fall off...could also be the switch pack on the side, but if you have to hold the gearlever in "D" suggests a linkage check is needed.
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
lpgelite
  • Cumbria
« Reply #7 on: 12 September 2008, 09:29:19 »
Phantom "engine oil" messages will be the sump sensor.
Had same problem with an ECOTEC Cavalier. Cost me £50 a few years back...
