Author Topic: LPG exhaust vapour?  (Read 1392 times)
omegod
  • liverpool
    • 2017 Seat Ateca
LPG exhaust vapour?
« on: 12 September 2008, 10:04:46 »
Been running my Elite for 4 months now and noticed a steamy ? exhaust when sitting at lights when all other cars arent producing any vapours.
Does LPG usually do this ?
All seems well with oil , water and temp so a bit curious.........
Re: LPG exhaust vapour?
« Reply #1 on: 12 September 2008, 10:08:20 »
I've not noticed it any better or worse on LPG, but Omegas do tend to steam quite a lot anyway, IME. I think because there's a fairly substantial exhaust system which doesn't run hot enough to fully vapourise the water during urban driving.
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #2 on: 12 September 2008, 11:32:29 »
Same here, lots of steam with gasoline only, and as Kevin Wood said, quite a lot of pipework under the car and cats are taking all the heat from the exhaust gas so mainly water is left...
Exec
  • Poland, Radom
« Reply #3 on: 12 September 2008, 11:56:40 »
don't worry, everything is ok
the products of lpg combustion are water vapour and CO2,
another thing is, the lpg combustion gives a bit higher temperature then gasoline combustion, so the exhaust gas also can be a bit warmer
here in Poland many many cars run on lpg, and it is normal to see 'clouds' of water vapour behind them (at lights for example) :)
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #4 on: 12 September 2008, 14:31:24 »
Cheers guys, the heads can stay on then!!!
