Author Topic: climate all over the shop  (Read 1277 times)
Dazzler
  • Haverhill, Suffolk
« on: 12 September 2008, 21:20:15 »
My climate is playing up, sometimes i cant get any any heat unless i have it set to HI.......then its too hot.
Sometimes it will regulate itself just fine :-/
Its starting to drive me nuts.........any ideas?????
Martin_1962
Re: climate all over the shop
« Reply #1 on: 12 September 2008, 21:59:55 »
Make sure you do not have anything on the daxh which might block the light sensor - eg map, hat, number plate.
« Reply #2 on: 13 September 2008, 02:02:05 »
only experience i had with this is when i changed the dash bulbs and unplugged the cid. When plugged back in and re built, the head unit only had radio volume, nothing else worked including the cid and climate which had heat and ac but nothing in between only adjustment was fan speed.
I took it all apart and checked the cid plugs, which where locked in place correctly, and then re built it again and bingo, cid, head unit and cc all working
fine. Not sure its relevant to yours as you dont mention any other issues but its all i can offer in clues. Hth some how.  :-/
Could also check the  supply from the vac pipes in the bulk head by the heater matrix pipes.
And the vac pipe on the hbv.
Pete Elite
  • Uxbridge, Middlesex
« Reply #3 on: 13 September 2008, 02:22:12 »
  Have you tried resetting it, i think by holding the OFF and AC buttons at the same time for 5 seconds.
Dazzler
« Reply #4 on: 13 September 2008, 11:33:01 »
Yep, tried resetting, makes no difference.
There is nothing covering the light sensor either.
Could it be something to do with the air sampler sensor????
