Author Topic: Misfire  (Read 1969 times)
MrTuco
  • South Yorkshire
Misfire
« on: 13 September 2008, 22:07:00 »
Ok, I am sure this is nothing new but I can't see this Q in FAQs, so I will try this out for size.  I have bought new Coil pack, leads, plugs, rocker covers. & guess what!!!!!!!!!!!!!! yesppers, it still misfires & pops. I have thrown 500 squid at this car so I now need to keep it. The engine management light is now on, so do I take it to VX for diagnosis or is there something I am missing? All I want is a car that runs nice.
Thank You Kindly. MrTuco (LDS)
Re: Misfire
« Reply #1 on: 13 September 2008, 22:11:35 »
done a paperclip test?
MutantCav
  • Gainsborough
Re: Misfire
« Reply #2 on: 13 September 2008, 22:14:05 »
Air leak?? Did you just replace stuff randomly to see if it fixed it?? If you have an EML light on then paperclip it :)
« Last Edit: 13 September 2008, 22:14:49 by ShieldOfSteel »
MrTuco
  • South Yorkshire
Re: Misfire
« Reply #3 on: 13 September 2008, 22:18:07 »
Ok, what is a paperclip test please?
Re: Misfire
« Reply #4 on: 13 September 2008, 22:29:24 »
Look here http://www.omegaowners.com/forum/YaBB.pl?num=1189022687 :)
MrTuco
  • South Yorkshire
Re: Misfire
« Reply #5 on: 13 September 2008, 23:12:22 »
OK, so I will do this test tomorrow & then post how many times it flashes & in what order, if this is correct then would someone be able to help me cure the car possibly?, I am sorry that I am not too good at this yet, but give me a few years & I will be ok at it..., cheers.
MrTuco
  • South Yorkshire
Re: Misfire
« Reply #6 on: 13 September 2008, 23:13:48 »
I just replaced everything at once as it is a pain to get to things,I just thought it easier & thought that would do the trick once & forall
MrTuco
  • South Yorkshire
Re: Misfire
« Reply #7 on: 14 September 2008, 12:09:47 »
Hi, I did the paperclip test & to be honest I just do not understand what I am looking at, the EML does flash but then flashes in different sequences. Any chance of someone calling me & talking me through it, I know I am a pain in the butt, & am sorry? So can you call? Please.
MrTuco
  • South Yorkshire
Re: Misfire
« Reply #8 on: 14 September 2008, 13:12:10 »
Re: Misfire
« Reply #9 on: 14 September 2008, 18:25:03 »
MrTuco
  • South Yorkshire
Re: Misfire
« Reply #10 on: 14 September 2008, 19:16:26 »
OK, I have done the "paperclip" test & these seem to be the codes I have, can anyone tell me what they mean please.........132-,59,-&31 Many Thanks.
Watch the video!! - http://images.omegaowners.com/images/guides/paperclip_test/paperclip.html
Re: Misfire
« Reply #11 on: 14 September 2008, 19:36:16 »
132   Exhaust Gas Recirculation (EGR) Valve Feedback Incorrect Signal
59   Intake Manifold Valve 1 Voltage Low
31   No Engine RPM Signal - normal with the engine not running :)
all here ... http://www.omegaowners.com/forum/YaBB.pl?num=1160152415
I'd be checking the connections around the engine to ensure evrything is plugged in properly ...
MrTuco
  • South Yorkshire
Re: Misfire
« Reply #12 on: 14 September 2008, 20:17:01 »
WOW that is awesome, ty so much, ok, my next thing is,  where is the manifold valve & do I just replace it & same with the EGR valve? any suggestions, I am sure all connections are good around the engine. Many thanks, you guys are Genius's you eally are...
Re: Misfire
« Reply #13 on: 14 September 2008, 20:20:22 »
Take the EGR valve off and clean it well ith paint sripper until the pintel inside moves freely, re-sit and then block the two ports off with a bit of coke can as I suspect it might be stuck open!
Check also the connection to the rear of the plenum which operates the multiram.
MrTuco
  • South Yorkshire
Re: Misfire
« Reply #14 on: 14 September 2008, 21:22:20 »
OK, where is the EGR valve located please & what is a Plenum & where is that located also please, & is the plenum part of the EGR valve or the other valve.? Sorry, I will learn soon & one day might be able to help others, or do you think there is no hope for me...lol, Cheers
