Author Topic: HID warning  (Read 1494 times)
BigCat
  • Battersea
HID warning
« on: 14 September 2008, 15:45:48 »
Just back from a long trip abroad, and I'm now getting a (HID) headlamp level warning error on the CID.
Any ideas on which part might be at fault, sensor or is there a module?
Thanks
The first 90% of a job takes 90% of the time, the last 10% takes the other 90% of the time.
    • 530D M Sport, 330i Coupe
Re: HID warning
« Reply #1 on: 14 September 2008, 15:51:48 »
Favourite culprit is the level sensor on the front n/s wishbone. Could also be rear level sensor or the actual levelling motors themselves.
serek
  • huntingdon
    • 3.2 mv6
Re: HID warning
« Reply #2 on: 14 September 2008, 15:55:21 »
where is located levelling motors themselves?. have same problem on mine allredy checked sensors and they looks ok
BigCat
  • Battersea
Re: HID warning
« Reply #3 on: 14 September 2008, 15:56:02 »
Thanks, sounds like there are two level sensors then, one front and one rear.
Does anyone know where the rear one is located?
serek
  • huntingdon
    • 3.2 mv6
Re: HID warning
« Reply #4 on: 14 September 2008, 15:57:12 »
rear ones nearly rear sunspension arm passengere side
Re: HID warning
« Reply #5 on: 14 September 2008, 15:57:26 »
On the rear suspension arm on the nearside. The one on the offiside is for the self levelling suspension.
« Last Edit: 14 September 2008, 15:58:09 by VXL_V6 »
BigCat
  • Battersea
Re: HID warning
« Reply #6 on: 14 September 2008, 16:04:43 »
Thanks for that, next question, mine is facelift, does anyone know if there are different versions?
Re: HID warning
« Reply #7 on: 14 September 2008, 16:41:10 »
All the same I believe
Re: HID warning
« Reply #8 on: 14 September 2008, 16:42:11 »
In the back of the headlights.  :y Specific type for HID's I believe.
serek
  • huntingdon
    • 3.2 mv6
Re: HID warning
« Reply #9 on: 14 September 2008, 16:51:11 »
thanx will look tonight
BigCat
  • Battersea
Re: HID warning
« Reply #10 on: 14 September 2008, 21:54:01 »
Cheers, I'm off tomorrow, so will hopefully sort it out!
