Author Topic: WHICH ONE IS WHICH  (Read 1651 times)
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
WHICH ONE IS WHICH
« on: 10 September 2008, 17:22:58 »
I have had the breathers off and cleaned today ,problem is I have got the two small pipies mixed up again  :-[ I did this last time too  :-X Question is which is which the one that goes to the metal connector with the small hole in .
 I have looked at the maint guide but it does not say which is which .
Also are the seals that are suggested are they they the strange shaped one that goes on the black plastic in to the hole on the plenum
JezInBrum
  • Birmingham
  • Built for comfort not speed
Re: WHICH ONE IS WHICH
« Reply #1 on: 10 September 2008, 18:25:29 »
Hi, the pipe i think you are refering to is the thin one off the breather block. This one goes in the left hand stub as you look from the front of the car.
http://i294.photobucket.com/albums/mm109/jezinbrum/10092008167.jpg
If this is the seal you are describing it goes bethern the plenum & the black breather that goes on top of the plenum. Depending of your car has the extended plenum or not you will need two thin o-rings for an early car & 4 for the later one with the extended casting.
Hope I have been of some assistance.
Jez
« Last Edit: 10 September 2008, 18:27:09 by JezInBrum »
« Reply #2 on: 10 September 2008, 18:31:41 »
Confirm wot he said ^^^^^^^^^
LFF64
  • HADDENHAM BUCKS
« Reply #3 on: 10 September 2008, 19:11:18 »
Yes that is the seal I meant any idea on the part number ?
The other seals are the two small o rings on the black casing
JezInBrum
  • Birmingham
« Reply #4 on: 11 September 2008, 01:33:42 »
90467543 £1.05 + vat
LFF64
  • HADDENHAM BUCKS
« Reply #5 on: 11 September 2008, 10:05:27 »
Thanks Jez  :y
« Reply #6 on: 11 September 2008, 10:31:18 »
Please read the manual
Read the rather maintenance guide!
« Reply #7 on: 11 September 2008, 19:09:36 »
LFF64 - as Mr DTM eluded to, there is a post in Maint Guides that explains all :y
willyboy
  • Leeds. West Yorks
  • Can Do !!
« Reply #8 on: 15 September 2008, 20:25:57 »
Hehehehehee
Love it  ! ;D ;D ;D
Page created in 0.026 seconds with 16 queries.
