Author Topic: EML  (Read 1691 times)
JezInBrum
  • Birmingham
  • Built for comfort not speed
EML
« on: 15 September 2008, 14:29:36 »
Hello, after a bit of advice.
Second time I have done cam cover gasket on my car. Anyway since then I have has EML come on, done obligatory test & codes 17 & 31 are flashing. Prior to refit I made doubly sure nothing was snagged or trapped. Any pointers please. Could it be a bad connection and are the faults likely to be linked? There wew only 5 things I dosconnected whilst replacing both gaskets. They were, EGR valve, ICV, left hand cam sensor & I assume knock sensor( both those had connections onto the cable tray) and the injector loom.
As stated I did my best to check nothing was trapped. Worst thing is bloody smell of oil is back again.
Thanks in advance.
Jez
ians
  • Reading
Re: EML
« Reply #1 on: 15 September 2008, 14:31:43 »
on the last bit, the oil smell can remain for a while as the old oil finds its way onto the exhaust,  so not to worry about that.  (Did you use genuine seals and sealant and torque it up correctly?
JezInBrum
  • Birmingham
Re: EML
« Reply #2 on: 15 September 2008, 14:46:31 »
Deffo genuine seals. Torqued up as best as poss, could not easily find a torque wrench that went that low.
Dazzler
  • Haverhill, Suffolk
Re: EML
« Reply #3 on: 15 September 2008, 14:56:27 »
Is it just the old oil burning off the manifolds or can you actually see a leak again :-/
JezInBrum
  • Birmingham
Re: EML
« Reply #4 on: 15 September 2008, 16:41:39 »
Smells worse than before, hopeflly just some oil that leaked out whilst they were changed
batista
  • yardley wood birmingham
Re: EML
« Reply #5 on: 15 September 2008, 16:59:13 »
have you reconnected the sensor on the rear of the plentum on passenger side ,i done this and forgot to connect it.. :y
JezInBrum
  • Birmingham
Re: EML
« Reply #6 on: 15 September 2008, 17:16:01 »
Yes that went on before plenum was secured. Strange thing is EML started flashing then went off for 5 mins now wont go off.
batista
Re: EML
« Reply #7 on: 15 September 2008, 17:26:40 »
have you checked the codes under the techical information eg code 17 knock signal and 31 no rpm signal.where in brum are you..
JezInBrum
  • Birmingham
Re: EML
« Reply #8 on: 15 September 2008, 17:31:50 »
I know 31 is crank sensor. See no reason for that to have gone. I feel its linked to the other one. Have no idea what knock sensor is, maybe to do with emissions???
I am in Erdington btw
« Last Edit: 15 September 2008, 17:33:34 by JezInBrum »
JezInBrum
  • Birmingham
Re: EML
« Reply #9 on: 16 September 2008, 12:08:40 »
Update....
started car this morning, EML still flickering. Drove a few hundred yards & it went off for a half mile then came back on. Will remove plenum l;ater & recheck all the connections again.
Any advice as to the fault codes please?
