Author Topic: Blaupunkt radio  (Read 1221 times)
hp7166
  • Bridgend
Blaupunkt radio
« on: 16 September 2008, 10:20:18 »
Hi Guys
I have a CD300 by Blaupunkt but need to get it out of the car to get the serial number as it wants a code does anyone have any tip?
CHeers
Rob :)
Welung666
Re: Blaupunkt radio
« Reply #1 on: 16 September 2008, 10:27:25 »
Has it got 4 small allen head grub screws on the edge of the face?
hp7166
  • Bridgend
Re: Blaupunkt radio
« Reply #2 on: 16 September 2008, 10:32:06 »
yes
Welung666
Re: Blaupunkt radio
« Reply #3 on: 16 September 2008, 10:46:53 »
They need to come out then off to Halfrauds for a set of stereo keys, basically 2 U shaped metal things. They fit into the holes and click into place then just pull!
hp7166
  • Bridgend
Re: Blaupunkt radio
« Reply #4 on: 16 September 2008, 10:52:43 »
ok thanks halfords here we come
hp7166
  • Bridgend
Re: Blaupunkt radio
« Reply #5 on: 17 September 2008, 08:42:06 »
Hi Guys
After a trip to halfords and £4.29 later the stero was removed, i have the code for the Radio now but it says 6-Safe on the screen. I have turned the system on holding the AS button but it still does not work
Hope you can help
Rob
bobbertbear
  • perth
    • 04 omega 3.2 ex plod
Re: Blaupunkt radio
« Reply #6 on: 17 September 2008, 08:47:20 »
you need to leave the radio switched on as there is a time limit on each code entry after the first three,so might be 10 mins or so then you should be able to enter the code
MutantCav
  • Gainsborough
Re: Blaupunkt radio
« Reply #7 on: 17 September 2008, 08:53:03 »
If you enter the code and it does not work (and your sure you entered it right) dont keep trying as your already down to just 6 attempts left...
hp7166
  • Bridgend
Re: Blaupunkt radio
« Reply #8 on: 17 September 2008, 09:16:10 »
ok thanks guys will try on the way home tonight
