Author Topic: r/h knock sensor routing  (Read 1857 times)
JueV6
  • Kent
« on: 17 September 2008, 09:48:59 »
has any one got the routing diagram for the r/h (O/S) knock sensor route please.
TIA
Julian
Re: r/h knock sensor routing
« Reply #1 on: 17 September 2008, 10:06:25 »
1-3-5 Bank?
Quite simply it should pass over the top of the cam belt area (there are some plastic clips which attach to metal lugs on the cambelt backing plate but often break off) and down the back of the metal plate running behind the aux belt tensioner.
Richie London
  • heathrow
« Reply #2 on: 17 September 2008, 10:11:46 »
TIA
Julian
is there 2 knock sensors then ??????
« Reply #3 on: 17 September 2008, 10:15:49 »
TIA
Julian
Yes, one on each bank!
JueV6
  • Kent
« Reply #4 on: 17 September 2008, 11:45:40 »
Thanks mark, gonna fit 1 now , bwt the mv6 ecu stopped the eml light comming on 90% of the time so i think my lpg ecu doesn't like the thing jimbob was talking to you about , YOU know the small bit i'm talking about. :y :y
JueV6
  • Kent
« Reply #5 on: 17 September 2008, 16:33:39 »
Thanks for the Pm Mark, sorted now. Had to move the Alt but....thats where my vaporiser is so very little space. The sensor wire was frayed in 2 places behind the aux belt tensioner and it was chaffing on 1 of the lpg clips.routed where it should be now so hopefully that will cure it.
LPG
found a supplier for the BiGas system that I have fitted and they have told me that it IS the SGiS-N system that can be set by a serial lead and NOT the early one with the Dongle so will endevor to get a disk with the lead and software. then maybe that will sort the rough idle on gas. Solnoid repar kit for the noisy 1  (kit inc 4 x solnoid kits)£54
http://www.tinleytech.co.uk/home.html
Thanks again
Julian
