Author Topic: strange engine misfire  (Read 1509 times)
khatton
  • warrington cheshire
« on: 17 September 2008, 20:28:53 »
anyone know why i developed a slight misfire which seems worse when under load ie when in third gear trying to pick up speed when you know you should be in second really for the speed you are doing it seems to kick off more round corners changed plugs today no different pullled each lead of one by one but it didnot change the engine note on any of them you would not know it had a misfire on tickover it sounds ok just under a bit of load it appeares when starting of quick until you get the revs up then it goes away any ideas would be appreciated :'(
philhoward
  • Staffs
  • Love the engines, so put one in something else..
Re: strange engine misfire
« Reply #1 on: 17 September 2008, 20:52:32 »
Duff leads breaking down, or the DIS (coil) pack?
Was there any oil in the plug wells, or little lines up the sides of the plug caps?
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
Abiton
« Reply #2 on: 17 September 2008, 20:58:50 »
Have you still got the spark plugs you pulled out?
If so inspect the white insulators for any black lines up towards the contact, indicating tracking of the HT.  It may be that a lead has started to break down, and although you have new plugs, the lead is providing a leakage path up the side.
I had something similar w.r.t. the problem only being apparent under 'wrong gear' type load.  I blamed all sorts of things, but when I pulled the plugs out to do a compression test, pot 3's plug was really obviously suffering.  As it was Sunday, and I had no spares, I just cleaned the plug insulator ceramic, and the inside of the HT lead where it sits against this, problem gone.  :)
Edit: Too slow!  ;D
« Last Edit: 17 September 2008, 20:59:29 by Abiton »
khatton
« Reply #3 on: 17 September 2008, 21:11:29 »
not so sure what you mean about white lines but the plug holes were oily so the cam cover seals need doing but i cleaned them all before new plugs were put in would a good squirt of wd in the holes let me know if the spark is  tracking to the head it ran the same as soon as the plugs were changed and holes cleaned i would have thought you could get a few miles of good performance before the oil seeped in again thanks
prr
  • paignton devon
  • dont be scared to take it apart
« Reply #4 on: 17 September 2008, 22:03:45 »
ive just cured this problem on my 2l it started as a judder when goin round corners then it would pick up again it was fine on tickover but last week it got worse and the dis pac had failed on two pots replaced it and all is ok now i think it had been on its way out for a few weeks then just gave up the ghost
khatton
« Reply #5 on: 17 September 2008, 22:05:56 »
anyone know a way to test this please
