Author Topic: Oil Leak - but where?  (Read 5930 times)
« on: 17 September 2008, 00:13:52 »
Hi all,
A bit of a strange one here.
I have a leak on my 3.0 V6 Auto. Symptoms are as follows.
1) No noticable oil loss on the dipstick and no noticable ATF loss.
2) Oil is dripping from the bolts on the bottom of the engine, by the bellhousing. Parked overnight after a run, there are about 3 or 4 drops - enough to stain the road and annoy the neighbours ::)
3) The oil is a light browny colour. My ATF and engine oil are pretty much same colour, so hard to tell visually - but Kev W and I both agreed it didn't smell anything like ATF.
4) PAS fluid is leaking VERY slightly but doesn't need topping up between thousands of miles, and is the wrong colour and smell.
So in a nutshell, I think it is engine oil. There is also a little oil in the starter motor area and ABOVE the oil filter.
When I had the oil cooler out I noticed the pipe to cooler unions were leaking a fair amount, and these were changed, in the V.
The pipe to block unions are also dry.
So - guess this leaves two culprits. Cam cover gaskets, or rear crankshaft oil seal, (behind the flex plate) - in that order.
Does anyone agree / disagree?
I need to sort this - else it will be winding up the neighbours moreso than the lack of exhaust silencer  ;D
Re: Oil Leak - but where?
« Reply #1 on: 17 September 2008, 00:14:40 »
Just an aside - the plug wells are all dry...
« Reply #2 on: 17 September 2008, 00:18:08 »
Ive had the same (or similar)leak on my car since I bought it,still dont know where its from. :'(
« Reply #3 on: 17 September 2008, 00:20:14 »
I reckon there is a small external leak from the camcover gaskets - I just want someone to agree, before I
A) Shell out for new genuine ones and
B) Disturb my current ones, if they are actually sealing alright!
johnnycboy
  • Colchester
« Reply #4 on: 17 September 2008, 00:21:25 »
Me too, but i've only had the car three weeks.
James what about putting a bit of board down underneath the car for now, just to stop the neighbours complaining.
It must be a common fault with red facelift estates :'(
« Last Edit: 17 September 2008, 00:33:35 by johnnycboy »
« Reply #5 on: 17 September 2008, 08:41:27 »
Taste it....Would not be surprised given the location if it was coolant picking up some small amount of oil on its way down.
DaveyDavey
« Reply #6 on: 17 September 2008, 09:43:21 »
 :o
Crikey Mark I thought your knowledge of Omegas was good but that's going a little far isn't it?  ;)
« Reply #7 on: 17 September 2008, 09:46:47 »
making sure the local stray pooch has been nowhere near the car first ..........  ????
 :D :D :D :D :D
« Reply #8 on: 17 September 2008, 10:04:35 »
 :o
Lol, an old trick which really upstes the PC brigade.....works very well when you ahev antifreeze in a system!
« Reply #9 on: 17 September 2008, 10:08:57 »
I have smelt it... I can't smell sweet coolant in it, and I'm not losing coolant either  :-/
« Reply #10 on: 17 September 2008, 10:17:59 »
You wont be able to smell it.....taste it!
« Reply #11 on: 17 September 2008, 10:25:46 »
Ok - I'll give it a lick when I get home tonight  ::)
It stains the road quite badly though - would it do that if it was largely coolant?  :-/
It also burns off the cats on a fast run - stinks ..
« Reply #12 on: 17 September 2008, 10:32:52 »
Yes it would as I suspect there may be oil and crudd in the mix.
Need to rule out coolant as this mixed with a small amount of oil spreads a long way!
What I am effectively saying is.....rule out the coolant first as that seriously narrows the possibles down  :y
« Last Edit: 17 September 2008, 10:33:35 by Mark »
« Reply #13 on: 17 September 2008, 10:33:40 »
If the neighbours see you licking the road,you might end up in a padded cell. :D ;D ;D
« Reply #14 on: 17 September 2008, 10:52:56 »
There's still some on my driveway. >:( I'll let you come and lick it though. :P
I remember having a feel in the bottom of the bellhousing as we initially wondered if it was the TC seal. It was dry in there IIRC, making the rear crank seal less likely. I think you would have noticed that when you had the autobox off too.
Another option is to touch it with something hot I.E. a soldering iron. If there's water content it will fizz as the water boils off. If it's all oil it will just smoke.
