Author Topic: 2.5 V6 HT leads  (Read 1482 times)
nen3906
  • Tamworth
2.5 V6 HT leads
« on: 19 September 2008, 09:18:02 »
Good morning
                 How easy is it to change the HT leads on my 2.5 V6, looking at them, they appear to go behind the engine somewhere !!!! ;)
Re: 2.5 V6 HT leads
« Reply #1 on: 19 September 2008, 09:33:14 »
Good morning
Its a pig frankly. You cant see the dis pac. All done by feel but it can be done. Very easy to get the order wrong. There is a guide in maintenance section i think, and have a search there are a phew hand drawn diagrams on which plug goes where. Hth
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: 2.5 V6 HT leads
« Reply #2 on: 19 September 2008, 11:22:16 »
one lead at a time
Re: 2.5 V6 HT leads
« Reply #3 on: 19 September 2008, 11:23:26 »
Take the plenum off and remove the cable tray on the passenger side and its pretty easy.
Re: 2.5 V6 HT leads
« Reply #4 on: 19 September 2008, 11:26:16 »
Good morning
They lead to a DIS pack mounted on the back of the engine, replace one lead at a time, as the number sequence on the dispack is not the usual format you would expect.
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: 2.5 V6 HT leads
« Reply #5 on: 19 September 2008, 11:38:01 »
changed a Vectra V6 Dispack and that was
1 3 5
2 4 6
but the v6 vectras dispack has a different p/n to a v6 miggy one so knowing vaxuhall its problably different
Re: 2.5 V6 HT leads
« Reply #6 on: 19 September 2008, 11:53:47 »
1 3 5
2 4 6
There the same DIS packs (although the V6 used 3 different ones through the production era which explains where the confusion can come from).
And all have the same HT connections:
1 3 5
4 6 2
And there is a simple reason why its like this.
Thats because the setup uses a wasted spark and given the firing order is 1-2-3-4-5-6 you will be firing the following
[td]Cylinder[/td]
[tr][td]Firing [/td][td]Exhaust[/td][/tr]
[tr][td]1[/td][td]4[/td][/tr]
[tr][td]2[/td][td]5[/td][/tr]
[tr][td]3[/td][td]6[/td][/tr]
[tr][td]4[/td][td]1[/td][/tr]
[tr][td]5[/td][td]2[/td][/tr]
[tr][td]6[/td][td]3[/td][/tr]
[/table]
So, given that the coil pack has 3 coils in it arranged as
0  0  0
3  3  3
0  0  0
It means that when you connect 1-3-5 to one side then the other ones must be 4-6-2  :y
nen3906
  • Tamworth
Re: 2.5 V6 HT leads
« Reply #7 on: 19 September 2008, 14:06:23 »
Thank you, ill be trying it this weekend.
