Author Topic: Sports Button  (Read 7929 times)
hp7166
  • Bridgend
Sports Button
« on: 17 September 2008, 09:52:30 »
Hi Guys
I have a 2.5TD Omega 1995 and the sports button seems to do nothing to the car. The light on the dash comes on but the car feels the same.
Thanks for your help
Rob :)
johnnycboy
  • Colchester
Re: Sports Button
« Reply #1 on: 17 September 2008, 09:56:05 »
Hi Guys
Rob :)
As far as i'm aware the sports button holds the gears to a higher rev :y hth
just asking what is your perception of what the sports button does :question
Re: Sports Button
« Reply #2 on: 17 September 2008, 09:56:21 »
all it does it hold gears for longer, and let it rev to the red line.
Ohh and it also locks out 4th, will always stay in 3rd no matter what speed you do...
« Last Edit: 17 September 2008, 09:57:14 by tunnie »
johnnycboy
  • Colchester
Re: Sports Button
« Reply #3 on: 17 September 2008, 10:03:40 »
That sounds like why my gearbox is fooked. last owner must have been a sports button maniac :(
hp7166
  • Bridgend
Re: Sports Button
« Reply #4 on: 17 September 2008, 10:10:33 »
ok never tired to see if the thing to see if the revs are higher but will have ago, i dont think i will use it that much anyway i value my fuel to much
Re: Sports Button
« Reply #5 on: 17 September 2008, 10:52:48 »
Get up to about 60 in top gear, ease back on the loud pedal, press the button, system should drop a gear. This sequence can be done in all gears.
If you want to try the heavy handed approach, stationary, select sports mode. floor it in a straight line, revs should rise to just below the red line in all gears before changing, and it should never go into top.
HTH
« Last Edit: 17 September 2008, 10:53:21 by entwood »
Re: Sports Button
« Reply #6 on: 17 September 2008, 11:47:27 »
Mine goes into top when it runs out of revs in 3rd at <mumble> MPH. :-X
Danny
  • Wigan, Greater Manchester
Re: Sports Button
« Reply #7 on: 17 September 2008, 18:25:15 »
might only need a software update!
johnnycboy
  • Colchester
Re: Sports Button
« Reply #8 on: 17 September 2008, 19:28:44 »
gearbox update done at Newent, still happening with mine  :-/
The Elite
  • Herts
  • Fuel duty still sucks...
Re: Sports Button
« Reply #9 on: 17 September 2008, 20:49:26 »
HTH
Surely if you floor it you will have it on the kick down switch and it'll hold the gears anyway?
« Last Edit: 17 September 2008, 20:49:50 by sledgehammer »
Mig 3 coming soon.... Watch this space!
Phil
Re: Sports Button
« Reply #10 on: 17 September 2008, 20:53:11 »
126 apparently!!
Funnily enough mine only stays in 3rd SINCE the gearbox update!!
Before it used to change up on the red line, now it doesn't!!
Is there an update of the update??
Oh and back on topic, the 'S' button means it also kicks down earlier  :)
Re: Sports Button
« Reply #11 on: 18 September 2008, 00:19:54 »
Sure mine goes into 4th in sport :-/
Re: Sports Button
« Reply #12 on: 18 September 2008, 04:51:24 »
Mine definitely does!  :y
philhoward
  • Staffs
  • Love the engines, so put one in something else..
Re: Sports Button
« Reply #13 on: 18 September 2008, 07:24:06 »
I thought its just 4th without lockup....
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
Banjax
  • Perth
Re: Sports Button
« Reply #14 on: 18 September 2008, 16:35:47 »
i use the "s" button a lot as i find it a bit too laggy without it - on a side issue - do the gearboxes on Mig's adjust their mapping as to how you drive? i remebmer my Galant auto had "fuzzy logic" that "learned" how you drove and changed gear accordingly - ie drive like a nutter - and it would rev higher in each gear (there was also a "hold" button in addition) but if you drove like an old lady it would slowly learn to change at lower revs
