Author Topic: Need Help with 2.2 oil leak  (Read 1897 times)
AHerrington
  • Dronfield Near Sheffield
« on: 20 September 2008, 12:52:29 »
Hi all,
I am relatively new to Omega's and I have a oil leak on my 2.2.
Everything was fine until i had the cam / timing belt changed.
All of a suden i have now got an oil leak. any ideas? should I have had something else done when had the belt changed.
Hope some one can Help
Andrew
Re: Need Help with 2.2 oil leak
« Reply #1 on: 20 September 2008, 13:03:53 »
Hi all,
Andrew
Was the belt replacement carried out by a garage? :-/ :-/
If so go back to them and complain about what has happened.  At least get an idea of what/where/how the oil leak has transpired.....but do not trust them!  Afterwards check for yourself or get a second opinion! ;)
As of now where do you believe the leak is from? :-/  Front, back, sides or underside of engine?
« Last Edit: 20 September 2008, 13:05:05 by Lizzie_Zoom »
AHerrington
« Reply #2 on: 20 September 2008, 13:08:05 »
I took it to a garage, I will take it back to them. It looks like the leak is coming from around the cam belt cover and over the big wheel/cog  at the front of the engine, sorry I am not mechanically minded or gifted.
Andrew
« Reply #3 on: 20 September 2008, 13:18:04 »
Andrew
Sounds to me Andrew as though they have not replaced a gasket (cam covers?) properly, or have not used new genuine Vx ones! >:(
Too true go back to them complain as I suggested before and hold your ground when they try (maybe) to charge you extra to put their shoddy work right!! ::) ::) ::) ::)
AHerrington
« Reply #4 on: 20 September 2008, 13:21:29 »
I bought the cam belt kit off ebay, genuine part, it had the belt and 3 wheels in the kid but had no gaskets, should i have got those as well or would the one already on the car been ok?
Andrew
« Reply #5 on: 20 September 2008, 13:21:29 »
Another thing Andrew were do you live (you have not entered it - even an approx. location - into your profile), and was/is it a Vauxhall main dealer garage?  :-/ :-/
In addition, to be really nosey, what did they charge? :-/ :-/ :-/
« Last Edit: 20 September 2008, 13:21:57 by Lizzie_Zoom »
« Reply #6 on: 20 September 2008, 13:22:50 »
but if they were just doing a cam belt, they'd have had no need to disturb cam covers.  :-/
AHerrington
« Reply #7 on: 20 September 2008, 13:23:49 »
I live near to sheffield, It wasn't a vauxhall garage but a local one who we have known for years, he charged me £65 to fit the belt.
The part was from ebay for £54. and vauxhall was going to charge me £280 for the part and fitting.
Andrew
« Reply #8 on: 20 September 2008, 13:25:49 »
Andrew
The gaskets do not come with the Cam Kit, but if the Cam covers were removed new gaskets for them should have been fitted.
I am sure that with a 2.2 straight 4-pot it is aviseable for the water pump to be replaced at the same time.
I am sure our real Omega engine experts on here will give you further advise in due course! :y :y
The first thing is though to go back to the garage, who on the face of it charged a very reasonable price if the job has been done to Vx standards. :y
« Last Edit: 20 September 2008, 13:27:47 by Lizzie_Zoom »
AHerrington
« Reply #9 on: 20 September 2008, 13:28:35 »
Thank you, much appreciated, Do you think it is and expensive job to stop the leak?
Andrew
« Reply #10 on: 20 September 2008, 13:29:58 »
That is what I think Andy, but it sounds as though they may have disturbed them for some reason :o :o
« Reply #11 on: 20 September 2008, 13:32:46 »
Thank you, much appreciated, Do you think it is and expensive job to stop the leak?Andrew
It does all depend on what is actually wrong and where on the engine before any thing can be reliably stated.
Come back to the Forum and let us all know what the garage have said before committing yourself.  At least that is what I would do if I had to use a garage again! :D ;)
« Reply #12 on: 20 September 2008, 13:35:35 »
There should be no need to touch anything other than the cambelt and hence the question would be, was the oil leak already there?
It is advisable to change the water pump on the 4 pots when doing the cambelt kit.
AHerrington
« Reply #13 on: 20 September 2008, 13:43:59 »
Prior to having the belt done there was no leak at all, and also the engine management light comes on when I start the car, I turn the ignition off and start it again and it goes off, does that have anything to do with it?
Andrew :(
