Author Topic: Front crankshaft oil seal on 2.0ltr  (Read 1213 times)
« on: 20 September 2008, 14:45:55 »
As heading. What`s involved. Difficulty? Special tools etc :-/ :-/
Re: Front crankshaft oil seal on 2.0ltr
« Reply #1 on: 20 September 2008, 15:07:02 »
On the cars I have worked on in the past, this involved removing the sump, crankshaft mountings, and slipping in oil seals.  If done yourself with car well raised it is not a too difficult job unless with the miggy you have to remove the crankshaft completely, then you are on to disconnecting big ends etc.
Real Omega engine specialist on here will no doubt advise! :y
« Reply #2 on: 20 September 2008, 15:09:10 »
Thanks for the input Lizzie :y
« Reply #3 on: 20 September 2008, 15:17:59 »
Thanks Rob; I just hope it is right for a miggy! ::) ::) ::)
« Reply #4 on: 20 September 2008, 15:25:40 »
Maybe someone out there will confirm :y
VX1
  • Reading, Berkshire
« Reply #5 on: 20 September 2008, 15:35:31 »
I have done one of these on my 2.0 ltr I had but I replaced it when I renewed the cambelt. It is easy to do but you have to remove the cambelt to get to it. Strip the front of the engine down as if you are doing a cambelt replacement. take off the crankshaft sprocket and put two screws into the seal and remove. On refitting the new oil seal remember to fit it carefully. Once you have done this then replace the sprocket and refit the cambelt to the correct specification.
HTH
Paul  :y
Vx Trade club card holder
Halfords trade card holder
« Reply #6 on: 20 September 2008, 15:38:56 »
HTH
Paul  :y
That's what was needed Paul; somebody who had actually done it on a miggy! :D :y :y
« Reply #7 on: 20 September 2008, 15:44:03 »
HTH
Paul  :y
Cheers Paul :y :y
Page created in 0.032 seconds with 16 queries.
