Author Topic: Faulty fuel filter connection  (Read 1231 times)
VX1
  • Reading, Berkshire
« on: 21 September 2008, 14:00:21 »
As you can see I have split the pipe going into the fuel filter and the connection is not sealing to the filter. My question is if I was to use new fuel pipe and connect it to the fuel tank then connect it to the fuel filter without using the securing clips but using a jubilee clip would this work or do I need to get a new pipe from the stealers?
Paul  :y
« Last Edit: 21 September 2008, 14:00:58 by vauxhallomega1 »
Vx Trade club card holder
Halfords trade card holder
Re: Faulty fuel filter connection
« Reply #1 on: 21 September 2008, 14:49:37 »
That`s what was used in the good old days. Can`t see there being any problems as long as the clips are tight ;D
« Reply #2 on: 21 September 2008, 15:01:50 »
Should work fine.
VX1
« Reply #3 on: 21 September 2008, 17:54:23 »
Well just to let you all know that I have done a temporary fix for now until I can get the new pipe. I went on a quick drive and came back and its still leaking but very very slight but should be ok. The clips are as tight as I dare to do them. What I done in the end was used the old pipe connected a pipe connector into the old pipe and fitted into the new 6mm pipe then connected onto the filter secured with a jubilee clip and job's a gud un.
Paul  :y
prr
  • paignton devon
  • dont be scared to take it apart
« Reply #4 on: 21 September 2008, 18:12:58 »
i did the same to mine i bust the clips to the filter and jubbly clips are ok on mine been there for a year and no leaks :y
Page created in 0.062 seconds with 16 queries.
