Author Topic: abs ecu intermittent fault  (Read 1304 times)
kris9128
« on: 21 September 2008, 18:01:14 »
hi all. need to pick your brains for a little while. have a slightly annoying fault on the abs ecu. the fault only happens once the engine gets upto running temp then comes and goes at will. have dis/re-conected ecu but faults is still there. any body got any ideas.
Re: abs ecu intermittent fault
« Reply #1 on: 21 September 2008, 18:05:52 »
Do you mean ABS & TC lights come on? Is speedo still working at the time they're on?
Suggest this is a knackered ABS ECU - it won't get any better only worse!  Search for ABS ECU - there's lots of help/comment on here.
kris9128
« Reply #2 on: 21 September 2008, 18:20:03 »
lose speedo, cruise, tc,abs and power steering at same time. it only started recently when i fitted new alternator. vx think i disturbed somthing whilst disconnecting battery but want to charge fortunes to fix it. always like to get a second opinion where vx dealers are concerned tho.
« Reply #3 on: 21 September 2008, 18:34:17 »
Hi Kris,
That happened to mine when I used jump leads once.  Vx will charge a fortune for a new ABS ECU.
However there's a company in Kent that will rebuild them for around £130 if my memory serves me right.  The downside is that it takes the car off the road for a few days as you have to take it out and post it off to them, but thats better than the ££££££££££'s that Vx will happily charge......
Can't remember what the company is called offhand, but a search on here should uncover it, if you have no joy get back to me and I'll go through my receipts.
Good Luck
Steve ;)
« Reply #4 on: 21 September 2008, 18:38:56 »
Other option is to buy second hand one (I paid about £40 for one).  Best to get one off exactly same year & model as yours else will require reprogging with Tech2.
Confirm you will lose anything "speed related" - thats power steering + cruise.
« Reply #5 on: 21 September 2008, 18:47:42 »
Have a look at this post - may help - http://www.omegaowners.com/forum/YaBB.pl?num=1221411004
« Reply #6 on: 21 September 2008, 23:42:51 »
Give bba-reman a ring .. they sorted mine out.. couriered the knackered one to them on Monday, they rang with the test results and a price for fixing Wednesday, after giving the go-ahead the unit arrived back on the Friday
01634 687222
That was 15 months ago, cost was £130 ... well impressed  :y :y
alenalper
  • Istanbul
« Reply #7 on: 22 September 2008, 05:56:18 »
i have problem with my omega also,x20xev.
abs light come on ,but  speedo and cruise is working.All working but light is on.Today i will go to opel service  :(
SUZUKI
GSXR 1000
K6
« Reply #8 on: 22 September 2008, 08:40:55 »
The common ABS fault only seems to affect 1998 and later cars. As yours is a 1997, I would get a tester plugged in and go from there.
« Reply #9 on: 22 September 2008, 08:43:14 »
Most likely to be a front wheel sensor at a guess.
« Reply #10 on: 22 September 2008, 08:45:54 »
As a general thing, having now taken one of these faulty modules apart, I can not see much that could be serviced on them as the main PCB is a true hybrid so pretty much un-touchable!.
There are two relays that might be an issue plus a load of welded type contacts which have also been known to be problematic.
So, if anybody has a failed unit I would like to try a repair on one of these (the original one I have has been sacrificed to get this far!)
« Reply #11 on: 22 September 2008, 08:51:11 »
On a 1996 2.0l which tech2 said ECU failed, I managed to get it working (as a temp fix) by taping relays with screwdriver handle.  As far as I know, it lasted some time, probably still is OK.  So sticky relays does sound a possibility.
From memory, think it was Nixoro's car, so if he is still around to comment?
