Author Topic: Headlamp Adjusters.  (Read 1751 times)
Pete Elite
  • Uxbridge, Middlesex
Headlamp Adjusters.
« on: 20 September 2008, 22:53:34 »
Hi,
   Can anyone put up a piccy of the Headlamp Adjusters on the projector type Headlamps :question.
        Cheers,
                   Pete.
markey mark
  • SLady bitshorpe north lincs
Re: Headlamp Adjusters.
« Reply #1 on: 21 September 2008, 00:36:13 »
doubt it pete they are normally in lots of small pieces !  ;D :D
Pete Elite
« Reply #2 on: 21 September 2008, 16:58:40 »
  Thanks Mark.
       Where abouts are they on the Headlamp unit?
VX1
  • Reading, Berkshire
« Reply #3 on: 21 September 2008, 18:14:28 »
At the back of the unit inside. You would need to dismantle the headlamp to get to it, you remove the lens very carefully.
Paul  :y
Vx Trade club card holder
Halfords trade card holder
Pete Elite
« Reply #4 on: 21 September 2008, 23:13:42 »
   Thanks Paul, i'll take a look :y.
« Reply #5 on: 22 September 2008, 08:19:26 »
If anybody has a broken one (with all the bits) I am after one to take some measurements off and see what I can do about fabricating a better solution.
« Reply #6 on: 22 September 2008, 08:44:03 »
If you want to borrow my spare projectors (think adjusters are in tact), let me know...  ...and while you have the lenses off, if you want to clean them as well  :P
« Reply #7 on: 22 September 2008, 08:53:06 »
If I can borrow one....dont fancy doing two although I suppose I could stretch to it!
« Reply #8 on: 22 September 2008, 09:00:58 »
No probs.
I don't mind doing the cleaning, its the lens removal that scares me  :-[
MutantCav
  • Gainsborough
« Reply #9 on: 22 September 2008, 14:25:54 »
If you remove the black rubber cover that covers the big hole in the back of the unit...you can see the black plastic adjuster inside...can also see if its broke or not (although the rattling unit pretty much gives away if it is lol)
Pete Elite
« Reply #10 on: 22 September 2008, 23:27:42 »
  Hi Chris,
             Are the adjusters the same on the earlier light units as they are on the Projector type as the bit you mention above is missing on my Projector and so is the longer of the 2 adjusters on the outside :(.
 So my  :question is can i just replace the older one into the newer one?
            Thanks,
                       Pete :y.
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #11 on: 22 September 2008, 23:48:22 »
  Hi Chris,
            Thanks,
                       Pete :y.
the older ones are white and a different shape (new black ones fit into groove but very brittle)
But you CAN replace new with old - i know coz the 2 projectors i bought from e-gay both had broken adjusters so i stripped down my old headlamps to make 2 good from 4 bad :y
Pete Elite
« Reply #12 on: 23 September 2008, 00:18:58 »
   Thanks for that HerefordElite :y.
