Author Topic: atf fluid  (Read 1158 times)
bighed
  • Shropshire
atf fluid
« on: 23 September 2008, 14:12:11 »
after a full drain down, how much atf is needed to fill up the 2.5 4 speed auto box?
Re: atf fluid
« Reply #1 on: 23 September 2008, 14:13:49 »
6-7 Litres, depending how much you get out of the TC
Varche
  • middle of Andalucia
    • Golf Estate
Re: atf fluid
« Reply #2 on: 23 September 2008, 14:17:45 »
I put just over 7 litros in mine. That was gearbox empty, very very little left in the torque converter. It will be less if you have just taken both sumps off with gearbox still in the car.
There was of course quite a bit left in the oil cooler pipes and cooler itself despite some coming out when you disconnect and then reconnect "crossed over".
I think I read somewhere that the grand total is 8.4 litros from dry.
varche
bighed
  • Shropshire
Re: atf fluid
« Reply #3 on: 23 September 2008, 14:33:39 »
Thanks guys  :y |Do i need to replace any gaskets if I drain it down fully?
« Last Edit: 23 September 2008, 14:35:23 by bighed »
Varche
    • Golf Estate
Re: atf fluid
« Reply #4 on: 23 September 2008, 15:03:04 »
As there isn't a drain plug thoughtfully provided you need to take a sump or two off to change the oil. Be prepared for some mess and have a receptacle to hand to catch the old oil!
For a standard change of fluid with or without the internal filter change you ideally need two gaskets. One for the smaller sump at the front and one for the larger sump at the back. You can get them mail order from a variety of places like JPat.
If you cannot get them then you could clean the surfaces and make a gasket with a suitable tube of goo.
varche
Re: atf fluid
« Reply #5 on: 23 September 2008, 18:59:50 »
varche
Just need to confirm with JPAT, but one of our members has organised a substaintial discount with JPAT :y
