Author Topic: Brake Pads  (Read 1335 times)
Brake Pads
« on: 23 September 2008, 15:44:09 »
On my 1998 Elite saloon front callipers/pads are Lucas pad part nş 9192124.
On the 1998 Elite Estate (both are V6s) front pads different shape - have "ears".  Believe they are ATE/Teves callipers/pads. Vx say only one type of pad (Lucas) - I say different having seen both types!!
Most aftermarket pad suppliers list both types for V6 Omegas.
Am I right in thinking Vx part nş for ATE pads is 91921213?
TIA
« Last Edit: 23 September 2008, 16:19:24 by dbug »
Re: Brake Pads
« Reply #1 on: 23 September 2008, 18:48:53 »
No one?
markey mark
  • SLady bitshorpe north lincs
Re: Brake Pads
« Reply #2 on: 23 September 2008, 18:51:48 »
of all the cars i have stripped the only difference i have found is the early 2.0 had smaller brakes all v6s are the same  :-/ :-/
Re: Brake Pads
« Reply #3 on: 23 September 2008, 18:56:34 »
All 6 cylinder cars, and all cars after 1997 have same front disks/pads, disks 296mm
Only pre 1997 2.0l petrols had the other type (along with 286mm disks)
Re: Brake Pads
« Reply #4 on: 23 September 2008, 18:58:41 »
Mark - pads on the Saloon std Lucass - on the Estate ATE (both 296 mm dia discs!
Estate ones look like this - http://cgi.ebay.co.uk/VAUXHALL-OMEGA-BRAKE-DISCS-BRAKE-PADS-296mm-ATE_W0QQitemZ330210802637QQihZ014QQcategoryZ10404QQcmdZViewItemQQ_trksidZp1713.m153.l1262
Saloon ones look like this - http://cgi.ebay.co.uk/VAUXHALL-OMEGA-FRONT-BRAKE-PADS-MINTEX-LUCAS_W0QQitemZ330210816528QQihZ014QQcategoryZ10404QQcmdZViewItemQQ_trksidZp1713.m153.l1262
I'm after gen Vx ones for Estate - Vx don't list them - thats y I'd like part nş confirmed.
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
Re: Brake Pads
« Reply #5 on: 23 September 2008, 19:06:51 »
All models except 2.0 to '97 -  9192124 Front pads
All models disc pads 93169001  - Rear pads :y
Edit: this is the one you have quoted - 2.0 to '97 9192123 Front pads
« Last Edit: 23 September 2008, 19:09:05 by alexandjen »
Trade club card holder
Code scanner available
markey mark
Re: Brake Pads
« Reply #6 on: 23 September 2008, 19:13:47 »
as i said all the cars i have worked on or stripped have had the pads in the second picture the others look like the early 286mm pads !  :-/
Re: Brake Pads
« Reply #7 on: 23 September 2008, 19:17:51 »
all except the 2.0 pre 97 have the lucas type, or at least left the factory with them.
if yours are different, someone has fooked around
Re: Brake Pads
« Reply #8 on: 24 September 2008, 01:55:50 »
Look carefully at the first ebay link http:// http://cgi.ebay.co.uk/VAUXHALL-OMEGA-BRAKE-DISCS-BRAKE-PADS-296mm-ATE_W0QQitemZ330210802637QQihZ014QQcategoryZ10404QQcmdZViewItemQQ_trksidZp1713.m153.l1262 - ATE pads & 296mm discs!
A number of aftermarket suppliers list ATE on V6s, 296 discs!  My understanding is that some ATE callipers were fitted on production line if Lucas parts not available.
« Last Edit: 24 September 2008, 01:58:12 by dbug »
Re: Brake Pads
« Reply #9 on: 24 September 2008, 08:03:08 »
Not on the Omega.  Vauxhall are pretty good for sticking to parts to be honest.
