Author Topic: Help please,leccy rear blind  (Read 2199 times)
chrisovkent
  • Ramsgate Kent
« on: 22 September 2008, 20:33:59 »
i got a gls with no rear leccy blind but i have got the switch in the dash for it,so i went off to my local vaux breakers today and picked a blind up,got it home and stripped the interior to fit it and noticed theres no plug/loom in the boot to connect it up :-[,i took the switch out to see if theres any wires running into the back and yep ther wires are there,so......how do i wire the leccy blind in?i was thinking that there might be a loom from the rear of the switch down to the foot well with a plug on the end and am rather hoping that i can go back to the scrappys and get the loom from the boot but its a 90 mile round trip,is this the case that i can get the loom,plug it into the the blind and run it through to another plug running from the back of the switch?thats what i'm hoping for,i know vauxhall looms are normally universal and carry the plugs for all the optional extra's and was shocked to find theres nothing in the boot for the blind,or is the plug hidden out of sight?many thanks in advance,Chris.
Re: Help please,leccy rear blind
« Reply #1 on: 22 September 2008, 20:35:56 »
If its not there, it needs 0v, ign 12v and a wire from the switch.
chrisovkent
  • Ramsgate Kent
« Reply #2 on: 22 September 2008, 20:40:46 »
so theres no plug and play way of doing it then?
« Reply #3 on: 22 September 2008, 20:50:17 »
If the loom is not there...
I'm surprised loom is missing though....
chrisovkent
  • Ramsgate Kent
« Reply #4 on: 22 September 2008, 20:56:08 »
yup i'm surprised as well cos normally vauxhall use the same looms throughout the range to save the expense of having different looms for different specs,a bit gutted to be honest as i was hoping to get it working tomorrow and i'm hopeless at electrics so no idea how to hard wire it in.
« Reply #5 on: 22 September 2008, 20:59:26 »
Some looms aren't fitted, for example the leccy seat loom.  Thought the blind one was included though...
chrisovkent
  • Ramsgate Kent
« Reply #6 on: 22 September 2008, 21:00:48 »
any idea where it might be hidden?
« Reply #7 on: 22 September 2008, 21:06:41 »
left hand side of boot, either just below or just above the shelf.
chrisovkent
  • Ramsgate Kent
« Reply #8 on: 22 September 2008, 21:08:00 »
thats what i thought....its not there  :-[
chrisovkent
  • Ramsgate Kent
« Reply #9 on: 22 September 2008, 23:24:41 »
does anyone know which colour wires are for what on this?theres 3 wires from the blind,1)red  2)brown and i think a blue and red,i take it one is for blind up,another is for blind down but what would the third be for?also would the wires in the back of the switch be coloured the same as on the blind?
« Reply #10 on: 23 September 2008, 08:59:04 »
Blimey, yours would be the first I have seen without the wires!
1)Red - Connect to F20 (on a facelift car this can be found feeding the seat heating by the base of the B post)
2)Brown - Ov, connect to a convenient piece of metal!
3)Blue and red - Connect to pin 2 of the switch
chrisovkent
  • Ramsgate Kent
« Reply #11 on: 23 September 2008, 09:42:51 »
been out this morning and defo no wires for it,gutted cos i thought i might find it with a fresh pair of eyes,raining hard now an i have got to go to the breakers as i've broke a couple of clips so guess who's getting soaked today !!!!! with the red wire you say connect to f20,what is f20 mate?also what is ov for the brown?thanks for your help as well much appreciated,looks like i'll be getting it working after all  ;)
« Reply #12 on: 23 September 2008, 09:56:57 »
0V is chassis ground so connect it to the car body work at a convenient point.
F20 is a fuse....but as said its easily found by the passenger or drivers seat as it also feeds the seat heaters (assuming the wiring for these is there!).
Realy surprised you cant find the loom, it is normaly taped to the main loom at the back left of the boot high up.
chrisovkent
  • Ramsgate Kent
« Reply #13 on: 23 September 2008, 10:09:33 »
when i disconnected the plug when taking the shelf out at the scrappys i made a mental note of where the plug was,when i got home its defo not there,theres no split in the main loom for it to exit from and go to the shelf,the only other loom that leaves the main loom in the same place as where the blind loom should be is for the fuel sender,its a strange one eh,the mig has got wires going into the base of the seats and the switches in the dash for the heated seats so fingers crossed it should'nt be too much of a problem.
chrisovkent
  • Ramsgate Kent
« Reply #14 on: 24 September 2008, 14:09:10 »
ok just a quicky,got the mig stripped to wire the blind  in and have found theres no f20 by the b pillar,can i run a live from the sender unit loom in the boot?
