Author Topic: v6 not starting...  (Read 1360 times)
merc v6
  • belfast N.ireland
  • this one comfortable car !!!
v6 not starting...
« on: 22 September 2008, 04:10:53 »
my omega wud not start the other day , jus kept winding over .. left it over nite an way hey started 1st pop ! then today again wud not start  :-[ sounded like it was not getin a spark ? checked the left hand side plugs an they wer full off oil ? how do i fix this ? wat caused it ? an how do u prevent it happening again ? all help much appreciated  8-)
Andyb
  • Lincoln
Re: v6 not starting...
« Reply #1 on: 22 September 2008, 07:37:51 »
need to change the cam cover gaskets m8 and its prob fooked the dis pack now so that will need replacing and your leads are prob been eaten away by the oil as well sorry not good news
johnnycboy
  • Colchester
« Reply #2 on: 22 September 2008, 07:45:11 »
try paperclip test and post results and get your cam gaskets done asap also breathers cleaned.
hth :y
Can you update your profile as well cheers
johnny :y
« Last Edit: 22 September 2008, 07:46:35 by johnnycboy »
merc v6
  • belfast N.ireland
« Reply #3 on: 22 September 2008, 12:50:07 »
cheers people .. am how much u reckon da get that done ? wat is the cam cover gasket ? oh an how u do a paper clip test ??  ;) im lost people when it cums da mechanical side of stuff  ;D
johnnycboy
  • Colchester
« Reply #4 on: 22 September 2008, 13:00:53 »
Update your profile with all your details car; reg etc :y.  Paperclip test depends on car, heres link http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
Cam cover gaskets under neath cam covers or rocker covers as they used to be known.  About £70. oof shop might have some.
hth
« Last Edit: 22 September 2008, 17:35:24 by johnnycboy »
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #5 on: 22 September 2008, 16:32:54 »
Cam Cover Gaskets are like the old Rocker Cover Gaskets, only one covers the Cams the other the Rockers.
When the breather system gets blocked the pressure build up blows the gaskets, or someone did not fit Genuine Vauxhall Gaskets last time they were changed....
If you have oil in the Spark Plug wells mate like already said get them done sooner rather than later. If you do it yourself probably cost you £80 with both Cam Cover Gaskets, 16 "O" rings plus gasket sealer (black sealant P/N 90485251).
Vauxhall Dealer will probably charge around £298 to do the Gaskets, the breathers will be extra.....
Also like said above do your "Paperclip Test" you could have a Crank Sensor braking down..
Anyway Good Luck :y
merc v6
  • belfast N.ireland
« Reply #6 on: 23 September 2008, 01:20:13 »
hello thanks 4 all the info people this is a very good site  ;) .. is it a hard job to do ? cud u do it urself ? is ther any special tools u need ? any 1 any step by step directions handy ?? 8-) thanks
johnnycboy
  • Colchester
« Reply #7 on: 23 September 2008, 08:46:21 »
Hi merc most of the info you will need to do them and other essential jobs yourself is within the maintenance guide.  They are very informative and have been put there courtesy of past and present OOF members/admin.
But just for you http://www.omegaowners.com/forum/YaBB.pl?num=1152564281
A good selection of torx sockets and torque wrench is a must.   still work out cheaper than taking to vx.
Try it yourself, very satisfying knowing you can do it yourself and any problems there is always someone on here who may be able to help. :y
« Reply #8 on: 24 September 2008, 02:12:47 »
If you do it yourself,the camcover bolts should only be done up to 8n/m (not much more than finger tight).if they are overtightened you will get similar problems reccuring. :y
p.s. if someone else is going to do it ,make sure they know this. :y
« Reply #9 on: 24 September 2008, 08:04:27 »
Yup, and if a garage does it, then will overtighten, and then when you go back coz its leaked, they will bring up the mythical expensive warped covers!
merc v6
  • belfast N.ireland
« Reply #10 on: 24 September 2008, 22:53:42 »
cheers people thanks 4 the info people ... but think il have da get some1 else da do id f**K it up lol but id b sure da pass the info on though ..  :y ps but if i do attempt it hope u guys have plenty off paitences  ;) lol
« Last Edit: 24 September 2008, 22:56:56 by merc_v6 »
